Ana içeriğe geç
Yardım
Sony Vaio Pro 13 Internal Battery Replacement
This guide outlines the steps required to replace the internal battery.
  • Yazar: Alex R
  • Tahmini süre: 10 dakika
  • Zorluk: Kolay
This guide shows how to replace the battery on the Sony Vaio Pro 13. Special care must be taken when handling Lithium-Ion batteries, avoid puncturing or bending the battery pack. Always recycle your old battery pack according to your local regulations.
Adım 1 Internal Battery  ¶
Once the bottom cover is removed, peel away the piece of tape located near the fan and heat sink assembly.
  • Once the bottom cover is removed, peel away the piece of tape located near the fan and heat sink assembly.
Adım 2  ¶
Remove the three 4.2mm Philips #0 screws located at the top of the battery. Simply lift the battery away from the computer.
Adım 2  ¶
  • Remove the three 4.2mm Philips #0 screws located at the top of the battery.
  • Simply lift the battery away from the computer.
