Ana içeriğe geç
Yardım
iPod Classic Click Wheel Replacement
  • Yazar: iRobot
  • Tahmini süre: 1 - 3 saat
  • Zorluk: Çok zor
The click wheel receives the feedback of your fingers and transmits it to the logic board.
Adım 1 Click Wheel  ¶
Use a spudger to flip up the plastic tab holding the orange display ribbon in place. The tab will rotate up 90 degrees towards the display, releasing the ribbon cable.
  • Use a spudger to flip up the plastic tab holding the orange display ribbon in place. The tab will rotate up 90 degrees towards the display, releasing the ribbon cable.
Adım 2  ¶
Slide the orange display ribbon cable directly out of its connector.
Adım 2  ¶
  • Slide the orange display ribbon cable directly out of its connector.
Adım 3  ¶
Lift the framework assembly up, and slide the display and LCD metal backplate out of the framework assembly.
Adım 3  ¶
  • Lift the framework assembly up, and slide the display and LCD metal backplate out of the framework assembly.
Adım 4  ¶
Remove the two Phillips screws securing the logic board to the framework.
Adım 4  ¶
  • Remove the two Phillips screws securing the logic board to the framework.
Adım 5  ¶
Carefully push the logic board away from the metal framework.
Adım 5  ¶
  • Carefully push the logic board away from the metal framework.
  • The logic board is secured to the framework with mild adhesive. Be careful not to bend the logic board by pushing too much in any one spot.
Adım 6  ¶
Move the click wheel from beneath the logic board so that the icons on the click wheel are visible.
Adım 6  ¶
  • Move the click wheel from beneath the logic board so that the icons on the click wheel are visible.
  • Use a spudger to flip up the plastic tab holding the orange click wheel ribbon in place. The tab will rotate up 90 degrees, releasing the ribbon cable.
Adım 7  ¶
Use a spudger to lift the click wheel cable off the logic board. Be careful not to bend the cable too much, or the electronics on the cable could be damaged.
Adım 7  ¶
  • Use a spudger to lift the click wheel cable off the logic board. Be careful not to bend the cable too much, or the electronics on the cable could be damaged.
  • When reinstalling the clickwheel, make sure that the click wheel cable is pushed all the way into its connector.
Adım 8  ¶
Slide the click wheel cable out of its connector.
Adım 8  ¶
  • Slide the click wheel cable out of its connector.
  • Lift the click wheel assembly away from the logic board.
  • Don't forget the click wheel button when putting your iPod back together.
