Ana içeriğe geç
Yardım
iPod Nano 3rd Generation Teardown
Teardown
Teardown
Teardown'lar device içerisine bakmanızı sağlar ve söküm talimatları olarak kullanılmamalıdır.
We disassembled this iPod on September 7, 2007.
Adım 1 iPod Nano 3rd Generation Teardown  ¶
There it is, in the same style box as the last Nano, but quite a bit shorter and wider.
  • There it is, in the same style box as the last Nano, but quite a bit shorter and wider.
Adım 2  ¶
Here's what you'll find in the box:
Adım 2  ¶
  • Here's what you'll find in the box:
  • A manual (even smaller than the iPod).
  • The usual, much-maligned headphones.
  • A USB to iPod cable.
  • A dock insert.
  • A brand new iPod.
Adım 3  ¶
The growing iPod Nano family.
Adım 3  ¶
  • The growing iPod Nano family.
  • Although the new Nano is shorter and wider than its older siblings, it has approximately the same area (36 square centimeters).
Adım 4  ¶
Apple appears to be going in circles. Anodized aluminum, shiny, anodized, shiny...
Adım 4  ¶
  • Apple appears to be going in circles. Anodized aluminum, shiny, anodized, shiny...
  • But of course, it's what's inside that counts.
Adım 5  ¶
And here's our first look inside this newest Nano.
Adım 5  ¶
  • And here's our first look inside this newest Nano.
  • The case has eight locking tabs:
  • Three on the left, evenly spaced.
  • Three on top.
  • Two on the right, near the bottom, to make room for the display circuitry at the upper right.
Adım 6  ¶
We've removed six Phillips screws fixing the logic board to the casing.
Adım 6  ¶
  • We've removed six Phillips screws fixing the logic board to the casing.
  • We can now lift the logic board up, but it's still tethered by the visible click wheel cable and the hidden display cable.
Adım 7  ¶
We've disconnected the click wheel cable and flipped the board over to disconnect the display cable.
Adım 7  ¶
  • We've disconnected the click wheel cable and flipped the board over to disconnect the display cable.
Adım 8  ¶
Now we use a spudger to pry up the display, which is held along the case's edge by an adhesive strip.
Adım 8  ¶
  • Now we use a spudger to pry up the display, which is held along the case's edge by an adhesive strip.
  • The first generation Nano's display was attached in exactly the same way. If you're not careful when prying it up, you may crack it.
Adım 9  ¶
We're noticing a strong trend as we take apart this iPod: adhesive.
Adım 9  ¶
  • We're noticing a strong trend as we take apart this iPod: adhesive.
  • The click wheel is held in place by nothing but a very strong adhesive, which is going to make replacing it difficult. You'll have to get it to stay in place as well as Apple has (i.e. very well).
Adım 10  ¶
Here the battery is out of its metal housing, which is attached to the logic board by, that's right, adhesive.
Adım 10  ¶
  • Here the battery is out of its metal housing, which is attached to the logic board by, that's right, adhesive.
  • The battery is attached to the logic board by three through-hole solder points, as in the second generation Nano (sorry, no easy replacements).
Adım 11  ¶
And here's everything together again, but apart.
Adım 11  ¶
  • And here's everything together again, but apart.
Adım 12  ¶
A close-up of the logic board's top, which sports an eight gigabyte Samsung flash memory chip and headphone jack.
Adım 12  ¶
  • A close-up of the logic board's top, which sports an eight gigabyte Samsung flash memory chip and headphone jack.
  • The headphone jack is soldered to the logic board, as in the first generation Nano, but not in the second.
Adım 13  ¶
A close-up of the logic board's bottom.
Adım 13  ¶
  • A close-up of the logic board's bottom.
Adım 14  ¶
And it still works! Now, having satisfied our curiosity, we can put some music on it.
Adım 14  ¶
  • And it still works! Now, having satisfied our curiosity, we can put some music on it.
