Ana içeriğe geç
Yardım
PowerBook G4 Titanium Mercury Lower Case Replacement
Just remove a few Phillips screws, and the bottom case slides off.
Adım 1 Lower Case  ¶
Resim yok
Adım 1 Lower Case  ¶
  • Turn the G4 over.
  • Remove the eight Phillips screws from the lower case.
Adım 2  ¶
Using your thumbs, slide the lower case away from you.
Adım 2  ¶
  • Using your thumbs, slide the lower case away from you.
  • The lower case may stick in the front on a tab just above the center of the DVD drive. Be careful as you work the case off, or you may break the thin strip of plastic just above the drive.
  • Lift the lower case off.
Adım 3  ¶
Your laptop should look approximately like this.
Adım 3  ¶
  • Your laptop should look approximately like this.
