Ana içeriğe geç
Yardım
PowerBook G4 Titanium Mercury Hard Drive Replacement
Öne Çıkan Kılavuzlar
Bu kılavuz, iFixit kadrosu tarafından acayip havalı bulundu.
You can install hard drives up to 12.5mm thick.
Adım 1 Hard Drive  ¶
Remove the two black plastic bumpers and two T8 Torx screws from the side of the hard drive.
Adım 1 Hard Drive  ¶
  • Remove the two black plastic bumpers and two T8 Torx screws from the side of the hard drive.
Adım 2  ¶
Grasp the orange ribbon cable and disconnect it from the hard drive. If the connector is tight, gently rock it from side to side.
Adım 2  ¶
  • Grasp the orange ribbon cable and disconnect it from the hard drive. If the connector is tight, gently rock it from side to side.
  • Be sure to pull evenly on both sides as uneven force may damage the hard drive pins and render your data inaccessible.
  • If you are installing a new hard drive, we have an OS X install guide to get you up and running.
