Ana içeriğe geç
Yardım
MacBook Air 13" Mid 2011 AirPort/Bluetooth Card Replacement
Replace the AirPort/Bluetooth card in your MacBook Air 13" Mid 2011.
Use this guide to replace a dead AirPort/Bluetooth card to regain Wi-Fi capability.
Adım 1 AirPort/Bluetooth Card  ¶
Use the flat end of a spudger to pry both antenna connectors up from their sockets on the AirPort/Bluetooth card. Use the flat end of a spudger to pry both antenna connectors up from their sockets on the AirPort/Bluetooth card.
  • Use the flat end of a spudger to pry both antenna connectors up from their sockets on the AirPort/Bluetooth card.
Adım 2  ¶
Remove the single 2.9 mm T5 Torx screw securing the AirPort/Bluetooth card to the logic board.
Adım 2  ¶
  • Remove the single 2.9 mm T5 Torx screw securing the AirPort/Bluetooth card to the logic board.
Adım 3  ¶
Slightly lift the free end of the AirPort/Bluetooth card and pull it out of its socket on the logic board. To avoid damaging its socket on the logic board, do not excessively lift the free end of the AirPort/Bluetooth card.
Adım 3  ¶
  • Slightly lift the free end of the AirPort/Bluetooth card and pull it out of its socket on the logic board.
  • To avoid damaging its socket on the logic board, do not excessively lift the free end of the AirPort/Bluetooth card.
  • Remove the AirPort/Bluetooth card from the Air.
