Ana içeriğe geç
Yardım
MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Upper Case Replacement
Salt Önkoşul
Salt Önkoşul
Bu kılavuzun yalnızca diğer kılavuzlar için bir önkoşul kılavuzu olduğunu lütfen dikkate alın.
Changing the top case will also give you a new trackpad.
Adım 1 Upper Case  ¶
Remove the two 2.8 mm Phillips screws in the battery compartment near the latch.
Adım 1 Upper Case  ¶
  • Remove the two 2.8 mm Phillips screws in the battery compartment near the latch.
Adım 2  ¶
Remove the following 6 screws:
Adım 2  ¶
  • Remove the following 6 screws:
  • Two 10 mm T6 Torx screws on either side of the RAM slot.
  • Four 14.5 mm Phillips screws along the hinge.
Adım 3  ¶
Remove the four 3.2 mm PH00 Phillips screws on the port side of the computer.
Adım 3  ¶
  • Remove the four 3.2 mm PH00 Phillips screws on the port side of the computer.
Adım 4  ¶
Rotate the computer 90 degrees and remove the two 3.2 mm Phillips screws from the rear of the computer.
Adım 4  ¶
  • Rotate the computer 90 degrees and remove the two 3.2 mm Phillips screws from the rear of the computer.
Adım 5  ¶
Rotate the computer 90 degrees again and remove the four 3.2 mm Phillips screws from the side of the computer.
Adım 5  ¶
  • Rotate the computer 90 degrees again and remove the four 3.2 mm Phillips screws from the side of the computer.
Adım 6  ¶
Do not yank the upper case off quickly. The case is attached to the logic board via a ribbon cable. Lift up at the rear of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case. There are four plastic clips above the DVD slot, and another above and to the left of the IR sensor.  These clips can be very difficult to disengage without prying.  They can also be difficult to re-engage during reassembly.
Adım 6  ¶
  • Do not yank the upper case off quickly. The case is attached to the logic board via a ribbon cable.
  • Lift up at the rear of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case.
  • There are four plastic clips above the DVD slot, and another above and to the left of the IR sensor. These clips can be very difficult to disengage without prying. They can also be difficult to re-engage during reassembly.
  • Reassembly Tip: Press down firmly on the tip of the top case above the location of each clip until you hear a snap to reseat them in their slots.
  • Reassembly Tip: The two center DVD clips will rarely snap back into place properly without help, and downward pressure will instead simply deform the frame around the DVD slot. Support the frame by inserting a plastic spudger into the DVD slot directly under the clip location until it is snug, then press down until you hear the snap.
Adım 7  ¶
Disconnect the trackpad and keyboard ribbon cable from the logic board, removing tape as necessary. Note: It is possible to replace the hard drive without disconnecting the keyboard from the chassis, but it will need to be held upright to keep it out of the way, while still allowing you both hands to work on the drive removal.
Adım 7  ¶
  • Disconnect the trackpad and keyboard ribbon cable from the logic board, removing tape as necessary.
  • Note: It is possible to replace the hard drive without disconnecting the keyboard from the chassis, but it will need to be held upright to keep it out of the way, while still allowing you both hands to work on the drive removal.
  • Be careful when removing the keyboard-trackpad ribbon cable to ensure that the rear of the upper case is disengaged from the area near the hinge. It is easy to accidentally bend the screw receivers on either side of the keyboard.
  • Remove the upper case.
