Ana içeriğe geç
Yardım
Disassembling Kodak Advantix F350 Front Cover
Daha iyi giriş
Daha iyi giriş
Girişi tamamlayarak ya da daha iyi hale getirerek bu kılavuzu geliştirin.
This guide demonstrates how to remove the front and back cover from the camera.
Adım 1 Front Cover  ¶
Locate the 3 screws on the camera that hold the front cover of the camera to the camera body. The first 2 are located on the bottom of the camera.
  • Locate the 3 screws on the camera that hold the front cover of the camera to the camera body.
  • The first 2 are located on the bottom of the camera.
  • The last screw is located behind the flash module.
  • Turn the camera on, and raise the flash module to locate the flash module screw.
Adım 2  ¶
Remove the 2 screws at the base of the camera housing. Use the Phillips #00 Precision Screwdriver and remove the screws.
Adım 2  ¶
  • Remove the 2 screws at the base of the camera housing.
  • Use the Phillips #00 Precision Screwdriver and remove the screws.
  • Repeat this process for the screw behind the flash module.
Adım 3  ¶
Remove the screw located under the flash module using the Phillips #00 Precision Screwdriver. Remove the screw located under the flash module using the Phillips #00 Precision Screwdriver.
Adım 3  ¶
  • Remove the screw located under the flash module using the Phillips #00 Precision Screwdriver.
Adım 4  ¶
Remove the flash cover. Remove the flash module by twisting it up and outward of the camera housing.
Adım 4  ¶
  • Remove the flash cover.
  • Remove the flash module by twisting it up and outward of the camera housing.
  • The cover can now be be removed.
Adım 5  ¶
Remove the film door lever. Remove the screw holding the film lever in place by using a Phillips #00 Precision Screwdriver.
Adım 5  ¶
  • Remove the film door lever.
  • Remove the screw holding the film lever in place by using a Phillips #00 Precision Screwdriver.
  • Using a plastic opening tool, gently pry the switch upwards to remove it.
Adım 6  ¶
Open the battery door by pushing the lever towards the arrow indicated.
Adım 6  ¶
  • Open the battery door by pushing the lever towards the arrow indicated.
Adım 7  ¶
Remove the front cover. Insert your thumb in the film hole and gently pry the bottom loose. Once the front is loose, gently pull it out.
Adım 7  ¶
  • Remove the front cover.
  • Insert your thumb in the film hole and gently pry the bottom loose.
  • Once the front is loose, gently pull it out.
