Ana içeriğe geç
Yardım
Sony Ericsson W810I Vibration Cell Replacement
How to install a new vibration cell in your Sony Ericsson W810I.
Bölümler
Adım 1 Vibration Cell  ¶
This is the vibration cell.  It causes the phone to vibrate when the vibrate setting is active.
  • This is the vibration cell. It causes the phone to vibrate when the vibrate setting is active.
Adım 2  ¶
Insert the spudger into the crack between the green rubber container and the plastic case and pry it out.  When the cell it is about halfway out, remove the spudger. Reinsert the spudger into the crack between the metal top and the plastic case and pry it the rest of the way out. Reinsert the spudger into the crack between the metal top and the plastic case and pry it the rest of the way out.
Adım 2  ¶
  • Insert the spudger into the crack between the green rubber container and the plastic case and pry it out. When the cell it is about halfway out, remove the spudger.
  • Reinsert the spudger into the crack between the metal top and the plastic case and pry it the rest of the way out.
