Ana içeriğe geç
Yardım
iPad 3 4G Right Cellular Data Antenna Replacement
Replace the right antenna in your iPad 3 4G.
  • Yazar: Brett Hartt
  • Tahmini süre: 1 saat
  • Zorluk: Çok zor
This guide will help you replace the right antenna.
Adım 1 Right Cellular Data Antenna  ¶
Use the tip of the iSesamo or the edge of a plastic opening tool to remove the metal EMI tape covering the antenna cable. When removing the EMI tape from the cable itself, be sure that you are sliding the iSesamo between the tape and the cable, and not between the cable and the aluminum housing. When removing the EMI tape from the cable itself, be sure that you are sliding the iSesamo between the tape and the cable, and not between the cable and the aluminum housing.
  • Use the tip of the iSesamo or the edge of a plastic opening tool to remove the metal EMI tape covering the antenna cable.
  • When removing the EMI tape from the cable itself, be sure that you are sliding the iSesamo between the tape and the cable, and not between the cable and the aluminum housing.
Adım 2  ¶
Remove the two 1.75 mm Phillips #00 screws securing the antenna to the aluminum frame.
Adım 2  ¶
  • Remove the two 1.75 mm Phillips #00 screws securing the antenna to the aluminum frame.
Adım 3  ¶
Using your fingers or a spudger, lift the antenna out of its socket, rotating it toward the bottom of the device. Make sure that the orange ribbon cable passes completely through its hole in the aluminum frame.
Adım 3  ¶
  • Using your fingers or a spudger, lift the antenna out of its socket, rotating it toward the bottom of the device.
  • Make sure that the orange ribbon cable passes completely through its hole in the aluminum frame.
Adım 4  ¶
Insert the flat end of a spudger underneath the adhesive tape securing the antenna cable to the aluminum frame.
Adım 4  ¶
  • Insert the flat end of a spudger underneath the adhesive tape securing the antenna cable to the aluminum frame.
  • Slide the cable to the left, releasing the adhesive.
Adım 5  ¶
Holding the antenna cable firmly in your fingers, pull the cable off of the aluminum frame. Minding any cables that may get caught, remove the antenna from the iPad. Minding any cables that may get caught, remove the antenna from the iPad.
Adım 5  ¶
  • Holding the antenna cable firmly in your fingers, pull the cable off of the aluminum frame.
  • Minding any cables that may get caught, remove the antenna from the iPad.
