Ana içeriğe geç
Yardım
iMac Intel 17" Speakers Replacement
Is your iMac always mute? Replace your speakers and crank those tunes!
Bölümler
Aletler
Adım 1 Speakers  ¶
Remove the 30 mm T10 Torx screw securing the left speaker to the rear case.
Adım 1 Speakers  ¶
  • Remove the 30 mm T10 Torx screw securing the left speaker to the rear case.
Adım 2  ¶
Remove the 17 mm T10 Torx screw from the right speaker.
Adım 2  ¶
  • Remove the 17 mm T10 Torx screw from the right speaker.
Adım 3  ¶
Pull the SATA data cable connector away from its socket on the logic board.
Adım 3  ¶
  • Pull the SATA data cable connector away from its socket on the logic board.
  • The SATA connector on most iMacs tends to stick in its socket on the logic board. If you are having trouble disconnecting the SATA cable, insert a metal spudger or any other thin tool into the gap between the SATA connector and its socket and twist the spudger's shaft to safely separate the two pieces.
Adım 4  ¶
Disconnect the CPU fan by pulling its connector up off the logic board.
Adım 4  ¶
  • Disconnect the CPU fan by pulling its connector up off the logic board.
Adım 5  ¶
Disconnect the hard drive power cable by pulling its connector up off the logic board.
Adım 5  ¶
  • Disconnect the hard drive power cable by pulling its connector up off the logic board.
Adım 6  ¶
Use the flat end of a spudger to pry the AirPort Extreme antenna connector up off the AirPort Extreme card.
Adım 6  ¶
  • Use the flat end of a spudger to pry the AirPort Extreme antenna connector up off the AirPort Extreme card.
Adım 7  ¶
If necessary, remove any tape covering the left speaker cable.
Adım 7  ¶
  • If necessary, remove any tape covering the left speaker cable.
Adım 8  ¶
Lift the left and right speakers out of the rear case. The speaker cables are still attached to the logic board.
Adım 8  ¶
  • Lift the left and right speakers out of the rear case.
  • The speaker cables are still attached to the logic board.
  • The right speaker cable may be routed under the power button cable or the CPU fan cable (or both). If so, disconnect both cables by pulling their connectors away from the face of the logic board.
Adım 9  ¶
Disconnect the speaker cable connector by pulling its connector away from the socket on the logic board.
Adım 9  ¶
  • Disconnect the speaker cable connector by pulling its connector away from the socket on the logic board.
  • Pull the connector parallel to the face of the logic board.
