Ana içeriğe geç
Yardım
Plantronics CS50 Headset Microphone Replacement
If the other person cannot hear you during the phone call, you may need to replace the microphone.
The following steps will teach you how to disassemble your headset and install a new microphone.
Bölümler
Aletler
Adım 1 Microphone  ¶
Use a hairdryer or heat gun to melt the adhesive along the crevice that joins the black and silver components. Apply additional heat at the tip of the microphone.
Adım 1 Microphone  ¶
  • Use a hairdryer or heat gun to melt the adhesive along the crevice that joins the black and silver components.
  • Apply additional heat at the tip of the microphone.
Adım 2  ¶
After heating the headset, use the plastic opening tool to carefully pry the black cover from the headset. Be aware of the two plastic connectors inside the headset. If the black cover does not come off smoothly, apply additional heat on the connectors.
Adım 2  ¶
  • After heating the headset, use the plastic opening tool to carefully pry the black cover from the headset.
  • Be aware of the two plastic connectors inside the headset. If the black cover does not come off smoothly, apply additional heat on the connectors.
Adım 3  ¶
Remove the microphone from the tip of the plastic. You will have to lift the microphone straight up because it is held in place by a small piece of plastic.
Adım 3  ¶
  • Remove the microphone from the tip of the plastic.
  • You will have to lift the microphone straight up because it is held in place by a small piece of plastic.
Adım 4  ¶
Use the heat gun to melt the adhesive connecting the headset face to the speaker casing. Use the plastic opening tool to separate the speaker casing from the headset face.
Adım 4  ¶
  • Use the heat gun to melt the adhesive connecting the headset face to the speaker casing.
  • Use the plastic opening tool to separate the speaker casing from the headset face.
  • Add extra heat to the sides to melt the adhesive between the plastic connectors.
Adım 5  ¶
Slowly separate the motherboard from the rest of the headset. Slowly separate the motherboard from the rest of the headset.
Adım 5  ¶
  • Slowly separate the motherboard from the rest of the headset.
Adım 6  ¶
Locate the microphone wires on the bottom of the motherboard.
Adım 6  ¶
  • Locate the microphone wires on the bottom of the motherboard.
  • Use a hairdryer or heat gun to melt the glue off of the motherboard.
Adım 7  ¶
Flip the device over.
Adım 7  ¶
  • Flip the device over.
  • Use a soldering iron to remove the solder that holds the wires to the motherboard.
  • For help soldering, click here.
  • The microphone piece should be completely detached from the motherboard.
