Giriş
After performing all possible software troubleshooting, if you're headphone jack still doesn't work, you will have to replace the entire motherboard because the jack is permanently attached to the motherboard.
Neye ihtiyacın var
Use a PH000 screwdriver to unscrew the eleven 4mm Phillip head screws located on the back panel.
Bir başkası bu kılavuzu tamamladı.
