Ana içeriğe geç
hp pavilion 15-cc023cl Motherboard Replacement
Neye ihtiyacın var
  1. hp pavilion 15-cc023cl Motherboard Replacement, Battery: adım 1, 2 resimden 1. hp pavilion 15-cc023cl Motherboard Replacement, Battery: adım 1, 2 resimden 2.
    • Use a PH000 screwdriver to unscrew the eleven 4mm Phillip head screws located on the back panel.
  2. hp pavilion 15-cc023cl Motherboard Replacement: adım 2, 1 resimden 1.
    • Using the iFixit opening tool, pry open and remove the back cover of the laptop.
    • Be gentle when applying force to the cover.
  3. hp pavilion 15-cc023cl Motherboard Replacement: adım 3, 2 resimden 1. hp pavilion 15-cc023cl Motherboard Replacement: adım 3, 2 resimden 2.
    • Use a PH000 screwdriver to unscrew the four 3.5mm Philips head screws located on the battery.
  4. hp pavilion 15-cc023cl Motherboard Replacement: adım 4, 2 resimden 1. hp pavilion 15-cc023cl Motherboard Replacement: adım 4, 2 resimden 2.
    • Disconnect the port connecting the battery and the motherboard and then remove.
  5. hp pavilion 15-cc023cl Motherboard Replacement, Hard Drive: adım 5, 1 resimden 1.
    • Use a spudger to lift the latch that holds the hard drive cable in place.
  6. hp pavilion 15-cc023cl Motherboard Replacement: adım 6, 1 resimden 1.
    • Use a plastic opening tool to pry the hard drive out.
  7. hp pavilion 15-cc023cl Motherboard Replacement: adım 7, 1 resimden 1.
    • Disconnect the hard drive cable.
  8. hp pavilion 15-cc023cl Motherboard Replacement: adım 8, 1 resimden 1.
    • Lift the plastic wedges up on both sides of the hard drive.
  9. hp pavilion 15-cc023cl Motherboard Replacement, Motherboard: adım 9, 1 resimden 1.
    • Locate the motherboard.
  10. hp pavilion 15-cc023cl Motherboard Replacement: adım 10, 2 resimden 1. hp pavilion 15-cc023cl Motherboard Replacement: adım 10, 2 resimden 2.
    • Use a PH0 screwdriver to unscrew the three 3 mm Phillips head screws located on the fan.
  11. hp pavilion 15-cc023cl Motherboard Replacement: adım 11, 1 resimden 1.
    • Use a PH1 screwdriver to unscrew the four 3mm Phillips head screws located on the processor cover.
    • Disconnect the cable.
  12. hp pavilion 15-cc023cl Motherboard Replacement: adım 12, 1 resimden 1.
    • Disconnect the plastic arm attached to the processor and remove.
    • Disconnect the cable attaching the fan to the motherboard and remove.
  13. hp pavilion 15-cc023cl Motherboard Replacement: adım 13, 1 resimden 1.
    • Use a PH1 screwdriver to unscrew one 3mm Phillips head screws on Wifi card.
    • Disconnect the Wifi card.
    • Be careful not to break any of the connectors.
  14. hp pavilion 15-cc023cl Motherboard Replacement: adım 14, 3 resimden 1. hp pavilion 15-cc023cl Motherboard Replacement: adım 14, 3 resimden 2. hp pavilion 15-cc023cl Motherboard Replacement: adım 14, 3 resimden 3.
    • Disconnect the 5 cables to keyboard and speakers.
    • You may have to pry some up with the spudger.
  15. hp pavilion 15-cc023cl Motherboard Replacement: adım 15, 2 resimden 1. hp pavilion 15-cc023cl Motherboard Replacement: adım 15, 2 resimden 2.
    • Use a PH1 screwdriver to unscrew six 3 mm Phillips head screws on the motherboard.
  16. hp pavilion 15-cc023cl Motherboard Replacement: adım 16, 1 resimden 1.
    • Use the iFixit opening tools to pry motherboard from back of laptop.
  17. hp pavilion 15-cc023cl Motherboard Replacement: adım 17, 1 resimden 1.
    • Disconnect SD and USB card cable.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
2Kılavuz Yorumları
Good job Stephany. I would’ve been lost without you…
your friend eternally,
Richey Dale
richeydale67 - Yanıt
How can i get this model motherboard
Adeyinka Alasi - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 37
Her zaman: 1,519
