Ana içeriğe geç
iBUYPOWER Trace 4 9310 M.2 NVMe Drive Replacement
Neye ihtiyacın var
  1. iBUYPOWER Trace 4 9310 M.2 NVMe Drive Replacement, M.2 NVMe Drive: adım 1, 2 resimden 1. iBUYPOWER Trace 4 9310 M.2 NVMe Drive Replacement, M.2 NVMe Drive: adım 1, 2 resimden 2.
    • Lay the desktop on its side with the glass panel facing up.
    • Remove the single screw.
  2. iBUYPOWER Trace 4 9310 M.2 NVMe Drive Replacement: adım 2, 2 resimden 1. iBUYPOWER Trace 4 9310 M.2 NVMe Drive Replacement: adım 2, 2 resimden 2.
    • Remove the glass side by pivoting it up with the bottom side still seated in the notches.
    • Lift the glass side out of the notches and set it to the side.
  3. iBUYPOWER Trace 4 9310 M.2 NVMe Drive Replacement: adım 3, 3 resimden 1. iBUYPOWER Trace 4 9310 M.2 NVMe Drive Replacement: adım 3, 3 resimden 2. iBUYPOWER Trace 4 9310 M.2 NVMe Drive Replacement: adım 3, 3 resimden 3.
    • Locate the M.2 drive that is right above the CPU.
    • Remove the screw on the edge of the drive.
  4. iBUYPOWER Trace 4 9310 M.2 NVMe Drive Replacement: adım 4, 2 resimden 1. iBUYPOWER Trace 4 9310 M.2 NVMe Drive Replacement: adım 4, 2 resimden 2.
    • The drive should lift up on the edge where the screw was.
    • Pull the drive out at an angle from the motherboard.
  5. iBUYPOWER Trace 4 9310 M.2 NVMe Drive Replacement: adım 5, 2 resimden 1. iBUYPOWER Trace 4 9310 M.2 NVMe Drive Replacement: adım 5, 2 resimden 2.
    • Line the new drive up with the slot and gently slide it in.
    • Use one finger to hold the drive down while you screw it back in.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
1Rehber Yorum
Thank you, Kilie, for the clear step-by-step instructions, together with pictures, for NVMe SSD installation.
George
George Meier - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 49
Son 30 gün: 169
Her zaman: 5,004
