Ana içeriğe geç
iBook G3 12" Keyboard Replacement
Neye ihtiyacın var
  1. iBook G3 12" Keyboard Replacement, Battery: adım 1, 1 resimden 1.
    • Use a coin to rotate the battery locking screw 90 degrees clockwise.
    • Lift the battery out of the computer.
  2. iBook G3 12" Keyboard Replacement, Keyboard: adım 2, 1 resimden 1.
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
    • If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw 180 degrees in either direction and try again.
    • Flip the keyboard over, away from the screen, and rest it face-down on the trackpad area.
  3. iBook G3 12" Keyboard Replacement: adım 3, 1 resimden 1.
    • If the computer does not have an Airport card installed, skip the next two steps.
    • Push the wire clasp toward the Airport card and pull it up to free it from the RAM shield.
  4. iBook G3 12" Keyboard Replacement: adım 4, 1 resimden 1.
    • Grasp the clear plastic tab on the Airport card and pull toward the right.
  5. iBook G3 12" Keyboard Replacement: adım 5, 1 resimden 1.
    • Hold the Airport card in one hand and use your other hand to remove the antenna cable.
  6. iBook G3 12" Keyboard Replacement: adım 6, 1 resimden 1.
    • Remove the two 2.5 mm Phillips screws that secure the RAM shield.
  7. iBook G3 12" Keyboard Replacement: adım 7, 1 resimden 1.
    • Grasp the metal bracket on top of the RAM shield and pull upward to remove the shield.
  8. iBook G3 12" Keyboard Replacement: adım 8, 1 resimden 1.
    • Pull the keyboard cable up from the logic board, holding the cable as close to the connector as possible.
Sonuç
17 farklı kişi bu kılavuzu tamamladı.
iRobot
1 İtibar
635 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 16
Her zaman: 11,010
