Ana içeriğe geç
iBook G3 12" Keyboard Replacement
Neye ihtiyacın var
    1. iBook G3 12" Keyboard Replacement, Battery: adım 1, 1 resimden 1.
      • Use a coin to rotate the battery locking screw 90 degrees clockwise.
      • Lift the battery out of the computer.
      FixBot'a Sor
      Yorum Ekle
    1. iBook G3 12" Keyboard Replacement, Keyboard: adım 2, 1 resimden 1.
      • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
      • If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw 180 degrees in either direction and try again.
      • Flip the keyboard over, away from the screen, and rest it face-down on the trackpad area.
      FixBot'a Sor
      Yorum Ekle
    2. iBook G3 12" Keyboard Replacement: adım 3, 1 resimden 1.
      • If the computer does not have an Airport card installed, skip the next two steps.
      • Push the wire clasp toward the Airport card and pull it up to free it from the RAM shield.
      FixBot'a Sor
      Yorum Ekle
    3. iBook G3 12" Keyboard Replacement: adım 4, 1 resimden 1.
      • Grasp the clear plastic tab on the Airport card and pull toward the right.
      FixBot'a Sor
      Yorum Ekle
    4. iBook G3 12" Keyboard Replacement: adım 5, 1 resimden 1.
      • Hold the Airport card in one hand and use your other hand to remove the antenna cable.
      FixBot'a Sor
      Yorum Ekle
    5. iBook G3 12" Keyboard Replacement: adım 6, 1 resimden 1.
      • Remove the two 2.5 mm Phillips screws that secure the RAM shield.
      FixBot'a Sor
      Yorum Ekle
    6. iBook G3 12" Keyboard Replacement: adım 7, 1 resimden 1.
      • Grasp the metal bracket on top of the RAM shield and pull upward to remove the shield.
      FixBot'a Sor
      Yorum Ekle
    7. iBook G3 12" Keyboard Replacement: adım 8, 1 resimden 1.
      • Pull the keyboard cable up from the logic board, holding the cable as close to the connector as possible.
      FixBot'a Sor
      Yorum Ekle
Sonuç
17 farklı kişi bu kılavuzu tamamladı.
iRobot
1 İtibar
635 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 13
Son 30 gün: 55
Her zaman: 11,502
