Giriş
Use this guide to replace the display data cable.
Use a coin to rotate the battery locking screw 90 degrees clockwise.
Lift the battery out of the computer.
Pull the keyboard release tabs (highlighted in red) toward you and lift up on the keyboard until it pops free.
If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw 180 degrees in either direction and try again.
Flip the keyboard over, away from the screen, and rest it face-down on the trackpad area.
Remove the following 9 screws on the bottom of the computer:
Three 3 mm Phillips around the battery compartment.
Three 5 mm Phillips on the left and bottom edges.
Three 14.5 mm Phillips on the top and right edges (you may have to peel back the foil tape to reveal the screw near the security lock slot).
Remove the following 16 screws:
Five 3 mm Phillips (these have smaller heads than the others).
Three 5 mm Phillips.
Eight 6 mm Phillips.
Disconnect the microphone cable from the front, left corner of the logic board.
Peel back the black tape and free the microphone cable from the hard drive.
Use a 1.5 mm hex screwdriver to remove the two hex screws on either side of the display (four screws total).
Remove the pieces of readily removable tape from around the perimeter of the display.
Carefully remove the aluminum tape covering the display data cable connection.
Remove the second of the two Phillips screws securing the clutch cover to the cast aluminum frame of the clutch hinges.
Remove the pieces of tape covering the display data and microphone cables near the bottom edge of the display.
