Ana içeriğe geç
iBook G3 14" Display Data Cable Replacement
Neye ihtiyacın var
    1. iBook G3 14" Display Data Cable Replacement, Battery: adım 1, 1 resimden 1.
      • Use a coin to rotate the battery locking screw 90 degrees clockwise.
      • Lift the battery out of the computer.
      FixBot'a Sor
      Yorum Ekle
    1. iBook G3 14" Display Data Cable Replacement, Keyboard: adım 2, 1 resimden 1.
      • Pull the keyboard release tabs (highlighted in red) toward you and lift up on the keyboard until it pops free.
      • If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw 180 degrees in either direction and try again.
      • Flip the keyboard over, away from the screen, and rest it face-down on the trackpad area.
      FixBot'a Sor
      Yorum Ekle
    2. iBook G3 14" Display Data Cable Replacement: adım 3, 1 resimden 1.
      • If your computer does not have an AirPort card installed, skip to the RAM shield removal step.
      • Push the wire clasp toward the AirPort card and pull it up to free it from the RAM shield.
      FixBot'a Sor
      Yorum Ekle
    3. iBook G3 14" Display Data Cable Replacement: adım 4, 1 resimden 1.
      • Grasp the clear plastic tab on the AirPort card and pull toward the right.
      FixBot'a Sor
      Yorum Ekle
    4. iBook G3 14" Display Data Cable Replacement: adım 5, 1 resimden 1.
      • Hold the AirPort card in one hand and use your other hand to remove the antenna cable.
      FixBot'a Sor
      Yorum Ekle
    5. iBook G3 14" Display Data Cable Replacement: adım 6, 1 resimden 1.
      • Remove the two Phillips screws that secure the RAM shield.
      FixBot'a Sor
      Yorum Ekle
    6. iBook G3 14" Display Data Cable Replacement: adım 7, 1 resimden 1.
      • Grasp the metal bracket on top of the RAM shield and pull upward to remove the shield.
      FixBot'a Sor
      Yorum Ekle
    7. iBook G3 14" Display Data Cable Replacement: adım 8, 1 resimden 1.
      • Pull the keyboard cable up from the logic board, holding the cable as close to the connector as possible.
      FixBot'a Sor
      Yorum Ekle
    1. iBook G3 14" Display Data Cable Replacement, Lower Case: adım 9, 1 resimden 1.
      • Use a pin to remove the three rubber feet from the lower case.
      FixBot'a Sor
      Yorum Ekle
    2. iBook G3 14" Display Data Cable Replacement: adım 10, 1 resimden 1.
      • Remove the three newly-revealed Phillips screws.
      FixBot'a Sor
      Yorum Ekle
    3. iBook G3 14" Display Data Cable Replacement: adım 11, 1 resimden 1.
      • Use a spudger or small flathead screwdriver to pry up the three metal rings that housed the rubber bumpers.
      FixBot'a Sor
      Yorum Ekle
    4. iBook G3 14" Display Data Cable Replacement: adım 12, 1 resimden 1.
      • Remove the three hex screws using a T8 Torx screwdriver.
      • The screw in the center is shorter than the other two.
      FixBot'a Sor
      Yorum Ekle
    5. iBook G3 14" Display Data Cable Replacement: adım 13, 1 resimden 1.
      • Remove the two Phillips screws on either side of the battery contacts.
      FixBot'a Sor
      Yorum Ekle
    6. iBook G3 14" Display Data Cable Replacement: adım 14, 1 resimden 1.
      • Breathe deeply. Trying times are ahead, but we promise the lower case does come off.
      • Push the thin rims of the lower case surrounding the battery compartment in, bending them past the tabs, and then lift up to free that corner of the lower case.
      FixBot'a Sor
      Yorum Ekle
    7. iBook G3 14" Display Data Cable Replacement: adım 15, 1 resimden 1.
      • There is a slot on the wall of the battery compartment that locks the lower case in place.
      • Use a small flathead screwdriver to pry out the slot's lower rim and pull up on the lower case to free the slot from the tabs holding it.
      FixBot'a Sor
      Yorum Ekle
    8. iBook G3 14" Display Data Cable Replacement: adım 16, 1 resimden 1.
      • Run a spudger along the seam between the lower case and upper case on the front of the computer to free the tabs locking the lower case.
      • Pull up on the lower case and continue to use the spudger as necessary until you hear three distinct clicks.
      FixBot'a Sor
      Yorum Ekle
    9. iBook G3 14" Display Data Cable Replacement: adım 17, 1 resimden 1.
      • Continue to run the spudger around the front, right corner.
      • There are two tabs on the port side of the computer, one near the front corner and one near the sound out port.
      FixBot'a Sor
      Yorum Ekle
    10. iBook G3 14" Display Data Cable Replacement: adım 18, 1 resimden 1.
      • Once the front and sides of the lower case are free, turn the computer so that the back is facing you.
      • Pull the lower case up and toward you until the back tabs pop free.
      • It may be helpful to jiggle the case up and down.
      FixBot'a Sor
      Yorum Ekle
    11. iBook G3 14" Display Data Cable Replacement: adım 19, 1 resimden 1.
      • Remove the small greasy springs with white plastic caps from either side of the battery contacts.
      FixBot'a Sor
      Yorum Ekle
    1. iBook G3 14" Display Data Cable Replacement, Upper Case: adım 20, 1 resimden 1.
      • All of the screws in the following step have small heads - the screws with larger heads hold the bottom shield on.
      • Remove the following 9 screws on the bottom of the computer:
      • Three 3 mm Phillips around the battery compartment.
      • Three 5 mm Phillips on the left and bottom edges.
      • Three 14.5 mm Phillips on the top and right edges (you may have to peel back the foil tape to reveal the screw near the security lock slot).
      FixBot'a Sor
      Yorum Ekle
    2. iBook G3 14" Display Data Cable Replacement: adım 21, 1 resimden 1.
      • Turn over the computer and open it.
      • Pry up the magnet covering a Phillips screw near the middle of the computer.
      • You may need to peel back the serial number sticker to access the magnet.
      FixBot'a Sor
      Yorum Ekle
    3. iBook G3 14" Display Data Cable Replacement: adım 22, 1 resimden 1.
      • Remove the following 3 screws on the edges of the keyboard area:
      • Two 6 mm Phillips underneath the keyboard area.
      • One 9 mm Phillips above the keyboard area.
      • On some models, there may also be a screw under the magnet you just removed. If so, remove the screw at this point.
      FixBot'a Sor
      Yorum Ekle
    4. iBook G3 14" Display Data Cable Replacement: adım 23, 1 resimden 1.
      • This is a diagram of the ribbon clamp connectors you will disconnect in the next step.
      • With your fingernails, grasp the locking bar on either side and pull up a small amount (about 1/16" or 2 mm).
      • After disengaging the locking bar, slide the cable out of the connector.
      FixBot'a Sor
      Yorum Ekle
    5. iBook G3 14" Display Data Cable Replacement: adım 24, 1 resimden 1.
      • Loosen the trackpad connector by pulling the top piece up slightly, freeing the trackpad ribbon.
      • Slide the orange trackpad ribbon out of the connector.
      FixBot'a Sor
      Yorum Ekle
    6. iBook G3 14" Display Data Cable Replacement: adım 25, 1 resimden 1.
      • Use a straightened paperclip to open the optical drive tray, and pull it out about halfway.
      FixBot'a Sor
      Yorum Ekle
    7. iBook G3 14" Display Data Cable Replacement: adım 26, 1 resimden 1.
      • Don't lift the upper case off the computer yet as there are still two cables left to disconnect.
      • Lift the upper case from the left side and use your other hand to pull out the right side in order to clear the power receptacle.
      FixBot'a Sor
      Yorum Ekle
    8. iBook G3 14" Display Data Cable Replacement: adım 27, 1 resimden 1.
      • The connectors at the ends of the cables are attached very firmly to the sockets on the logic board. Pulling directly on the cable will either separate the cable from its connector or the socket from the logic board.
      • Lift the upper case enough to disconnect the blue and white power cable from the logic board.
      • Using your fingernails or a dental pick, carefully pry the connector from its socket.
      • Make sure you are pulling only on the connector and not on the socket.
      FixBot'a Sor
      Yorum Ekle
    9. iBook G3 14" Display Data Cable Replacement: adım 28, 1 resimden 1.
      • Lift the upper case off completely and disconnect the red and black speaker cable from the logic board.
      FixBot'a Sor
      Yorum Ekle
    1. iBook G3 14" Display Data Cable Replacement, Top Shield: adım 29, 1 resimden 1.
      • Remove the following 16 screws:
      • Five 3 mm Phillips (these have smaller heads than the others).
      • Three 5 mm Phillips.
      • Eight 6 mm Phillips.
      FixBot'a Sor
      Yorum Ekle
      • If you have already removed the yellow tape, skip this step.
      • Peel back three strips of yellow tape in the bottom, left corner.
      • Peel back one strip of foil tape near the audio-out port, one near where the trackpad connects to the logic board, and one near where the screen latch used to be.
      FixBot'a Sor
      Yorum Ekle
    2. iBook G3 14" Display Data Cable Replacement: adım 31, 1 resimden 1.
      • Lift the top shield up from the right side, minding the upper left corner, which may catch on the metal framework.
      FixBot'a Sor
      Yorum Ekle
    1. iBook G3 14" Display Data Cable Replacement, Display: adım 32, 1 resimden 1.
      • If you have already removed the hard drive, ignore its presence in the following steps. The hard drive does not affect the display removal.
      • Disconnect the microphone cable from the front, left corner of the logic board.
      • Peel back the black tape and free the microphone cable from the hard drive.
      FixBot'a Sor
      Yorum Ekle
    2. iBook G3 14" Display Data Cable Replacement: adım 33, 1 resimden 1.
      • Use the black plastic handle to disconnect the display data cable from the logic board.
      FixBot'a Sor
      Yorum Ekle
    3. iBook G3 14" Display Data Cable Replacement: adım 34, 1 resimden 1.
      • If you have already removed the modem, you will only need to remove one of these screws.
      • Remove the two Phillips screws securing the display data cable to the metal framework.
      FixBot'a Sor
      Yorum Ekle
    4. iBook G3 14" Display Data Cable Replacement: adım 35, 1 resimden 1.
      • Deroute the display data and microphone cables, removing tape as necessary.
      FixBot'a Sor
      Yorum Ekle
    5. iBook G3 14" Display Data Cable Replacement: adım 36, 1 resimden 1.
      • Peel back the yellow tape securing the inverter cable to the metal framework.
      FixBot'a Sor
      Yorum Ekle
    6. iBook G3 14" Display Data Cable Replacement: adım 37, 1 resimden 1.
      • Disconnect the inverter cable from the logic board.
      • Carefully deroute the inverter cable from beneath the optical drive.
      FixBot'a Sor
      Yorum Ekle
    7. iBook G3 14" Display Data Cable Replacement: adım 38, 1 resimden 1.
      • Deroute the AirPort antenna cable from beneath the optical drive.
      FixBot'a Sor
      Yorum Ekle
    8. iBook G3 14" Display Data Cable Replacement: adım 39, 1 resimden 1.
      • Support the display with your free hand removing the following screws.
      • Remove the single Phillips screw on the outer edge of either hinge (two screws total).
      • Tilt the display back to get over two small nubbins, and then slide it directly from the case and away.
      FixBot'a Sor
      Yorum Ekle
    1. iBook G3 14" Display Data Cable Replacement, Rear Display Bezel: adım 40, 1 resimden 1.
      • Use a 1.5 mm hex screwdriver to remove the two hex screws on either side of the display (four screws total).
      • If you don't have a 1.5 mm hex driver, you can probably get these screws out with a T6 Torx screwdriver. However, if you use a T6 Torx driver you'll be more likely to strip the screws.
      FixBot'a Sor
      Yorum Ekle
    2. iBook G3 14" Display Data Cable Replacement: adım 41, 1 resimden 1.
      • Use your thumbs to slightly separate the rear bezel from the front bezel.
      • It is helpful to hold the opposing corner of the display stationary to aid in flexing the rear bezel away from the display.
      FixBot'a Sor
      Yorum Ekle
    3. iBook G3 14" Display Data Cable Replacement: adım 42, 3 resimden 1. iBook G3 14" Display Data Cable Replacement: adım 42, 3 resimden 2. iBook G3 14" Display Data Cable Replacement: adım 42, 3 resimden 3.
      • Insert the flat end of a spudger into the gap between the front and rear bezels.
      • Rotate your spudger until it is parallel to the front face of the display.
      • Run the spudger around the perimeter of the display to separate the rear bezel from its retaining clips.
      FixBot'a Sor
      Yorum Ekle
    4. iBook G3 14" Display Data Cable Replacement: adım 43, 1 resimden 1.
      • Lift the rear bezel off the display.
      FixBot'a Sor
      Yorum Ekle
    1. iBook G3 14" Display Data Cable Replacement, LCD Cover: adım 44, 2 resimden 1. iBook G3 14" Display Data Cable Replacement, LCD Cover: adım 44, 2 resimden 2.
      • Remove the pieces of readily removable tape from around the perimeter of the display.
      • Carefully remove the aluminum tape covering the display data cable connection.
      FixBot'a Sor
      Yorum Ekle
    2. iBook G3 14" Display Data Cable Replacement: adım 45, 2 resimden 1. iBook G3 14" Display Data Cable Replacement: adım 45, 2 resimden 2.
      • Remove the single screw inserted through the piece of EMI tape near the bottom edge of the display.
      • Use the tip of a spudger to remove the small washer under the screw you just removed.
      FixBot'a Sor
      Yorum Ekle
    3. iBook G3 14" Display Data Cable Replacement: adım 46, 1 resimden 1.
      • Peel the aluminum/EMI tape off the cast aluminum frame of the clutch hinges.
      • It is not necessary to peel the tape off the thin steel LCD cover.
      FixBot'a Sor
      Yorum Ekle
    4. iBook G3 14" Display Data Cable Replacement: adım 47, 2 resimden 1. iBook G3 14" Display Data Cable Replacement: adım 47, 2 resimden 2.
      • Remove the two Phillips screws securing each side of the LCD to the clutch hinge frame (four screws total).
      FixBot'a Sor
      Yorum Ekle
    5. iBook G3 14" Display Data Cable Replacement: adım 48, 1 resimden 1.
      • Lift the thin steel LCD cover off the LCD.
      FixBot'a Sor
      Yorum Ekle
    1. iBook G3 14" Display Data Cable Replacement, Clutch Cover: adım 49, 1 resimden 1.
      • Remove the second of the two Phillips screws securing the clutch cover to the cast aluminum frame of the clutch hinges.
      FixBot'a Sor
      Yorum Ekle
    2. iBook G3 14" Display Data Cable Replacement: adım 50, 3 resimden 1. iBook G3 14" Display Data Cable Replacement: adım 50, 3 resimden 2. iBook G3 14" Display Data Cable Replacement: adım 50, 3 resimden 3.
      • Pull the clutch cover away from the front of the display.
      • Keep track of the two covers that close the ends of the clutch cover. The third picture shows their correct orientation on the clutch cover.
      FixBot'a Sor
      Yorum Ekle
    1. iBook G3 14" Display Data Cable Replacement, Display Data Cable: adım 51, 1 resimden 1.
      • Remove the pieces of tape covering the display data and microphone cables near the bottom edge of the display.
      FixBot'a Sor
      Yorum Ekle
    2. iBook G3 14" Display Data Cable Replacement: adım 52, 1 resimden 1.
      • Disconnect the display data cable by pulling its connector away from the socket on the LCD.
      • Pull the connector parallel to the face of the LCD.
      • Remove the display data cable from the display.
      FixBot'a Sor
      Yorum Ekle
    3. iBook G3 14" Display Data Cable Replacement: adım 53, 2 resimden 1. iBook G3 14" Display Data Cable Replacement: adım 53, 2 resimden 2.
      • Use the tip of a spudger to lift the microphone out of the front bezel.
      • De-route the microphone cable from around the top and side of the display.
      FixBot'a Sor
      Yorum Ekle
    4. iBook G3 14" Display Data Cable Replacement: adım 54, 1 resimden 1.
      FixBot'a Sor
      Yorum Ekle
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 42
Her zaman: 1,981
