Ana içeriğe geç
iBook G3 Clamshell CD Faceplate Replacement
Neye ihtiyacın var
  1. iBook G3 Clamshell CD Faceplate Replacement, Battery: adım 1, 1 resimden 1.
    • Use a coin to turn both battery locking screws 90 degrees to the left.
    • Remove the battery cover.
    • Remove the battery from the computer by pulling up on the plastic tab.
  2. iBook G3 Clamshell CD Faceplate Replacement, CD Faceplate: adım 2, 1 resimden 1.
    • Use a straightened paperclip to manually eject the CD-ROM tray.
  3. iBook G3 Clamshell CD Faceplate Replacement: adım 3, 1 resimden 1.
    • Remove the single black Phillips screw from the center of the CD-ROM bezel.
  4. iBook G3 Clamshell CD Faceplate Replacement: adım 4, 1 resimden 1.
    • Grasp the CD-ROM bezel and rotate it upward to remove it from the drive.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
iRobot
1 İtibar
636 adet Kılavuz yazıldı
2 Yorum
There are two small black phillips screws which ALSO need to be removed ...... on some models. Although appearing identical, these covers are "similar" but NOT interchangeable between models of CD-Rom.
John Foster - Yanıt
Help I've broke my drive cover and it won't go back on how do I fix that
Mr. Yee Macinuwm - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 24
Her zaman: 10,128
