Ana içeriğe geç
iBook G3 Clamshell Modem Replacement
Neye ihtiyacın var
  1. iBook G3 Clamshell Modem Replacement, Battery: adım 1, 1 resimden 1.
    • Use a coin to turn both battery locking screws 90 degrees to the left.
    • Remove the battery cover.
    • Remove the battery from the computer by pulling up on the plastic tab.
    FixBot'a Sor
    Yorum Ekle
  2. iBook G3 Clamshell Modem Replacement, Airport Card: adım 2, 1 resimden 1.
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free. Note that the keyboard ribbon is still attached to the logic board, so you cannot completely remove the keyboard yet.
    • If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw (between F4 and F5 key) 180 degrees in either direction and try again.
    • Rotate the keyboard away from the screen and rest it face-down on the trackpad area.
    FixBot'a Sor
    Yorum Ekle
  3. iBook G3 Clamshell Modem Replacement: adım 3, 1 resimden 1.
    • If your computer does not have an airport card, you can skip the next two steps.
    • Grasp the clear plastic tab on the airport card and pull up and toward the display.
    FixBot'a Sor
    Yorum Ekle
  4. iBook G3 Clamshell Modem Replacement: adım 4, 1 resimden 1.
    • Hold the airport card in one hand and use your other hand to remove the antenna cable.
    FixBot'a Sor
    Yorum Ekle
  5. iBook G3 Clamshell Modem Replacement, Keyboard: adım 5, 1 resimden 1.
    • Remove the two Phillips screws that secure the RAM shield.
    FixBot'a Sor
    Yorum Ekle
  6. iBook G3 Clamshell Modem Replacement: adım 6, 1 resimden 1.
    • Grasp the wire metal bracket on top of the RAM shield and pull upward to remove the shield.
    FixBot'a Sor
    Yorum Ekle
  7. iBook G3 Clamshell Modem Replacement: adım 7, 1 resimden 1.
    • Pull up the keyboard connector cable by its clear plastic loop.
    FixBot'a Sor
    Yorum Ekle
  8. iBook G3 Clamshell Modem Replacement, Upper Case: adım 8, 1 resimden 1.
    • Use a straightened paperclip to manually eject the CD-ROM tray.
    FixBot'a Sor
    Yorum Ekle
  9. iBook G3 Clamshell Modem Replacement: adım 9, 1 resimden 1.
    • Turn the computer over so that the bottom is facing up.
    • Remove the following Torx screws:
    • Four short T8 Torx near the battery compartment.
    • Two long T8 Torx near the hinges.
    FixBot'a Sor
    Yorum Ekle
  10. iBook G3 Clamshell Modem Replacement: adım 10, 1 resimden 1.
    • Pull the CD-ROM drive tray partly out.
    • Remove the silver Phillips screw from the plastic casing.
    FixBot'a Sor
    Yorum Ekle
  11. iBook G3 Clamshell Modem Replacement: adım 11, 1 resimden 1.
    • Turn the computer over.
    • Remove the three Phillips screws.
    FixBot'a Sor
    Yorum Ekle
  12. iBook G3 Clamshell Modem Replacement: adım 12, 1 resimden 1.
    • This is a diagram of the trackpad ribbon clamp connector you will disconnect in the next step.
    • 1) With your fingernails, grasp the locking bar on either side and pull up a small amount (about 1/16" or 2 mm).
    • 2) After disengaging the locking bar, slide the cable out of the connector.
    FixBot'a Sor
    Yorum Ekle
  13. iBook G3 Clamshell Modem Replacement: adım 13, 1 resimden 1.
    • Loosen the trackpad clamp by pulling the top piece up slightly, freeing the trackpad ribbon.
    • Slide the orange trackpad ribbon out of the clamp.
    FixBot'a Sor
    Yorum Ekle
  14. iBook G3 Clamshell Modem Replacement: adım 14, 1 resimden 1.
    • Do not lift the upper case too far without first disconnecting the audio cable.
    • Push out the rim of the lower case and pull up on the upper case, grasping it just to the left of the optical drive.
    • Repeat the above step on the upper left corner of the upper case, grasping the bottom left corner of the upper case.
    FixBot'a Sor
    Yorum Ekle
  15. iBook G3 Clamshell Modem Replacement: adım 15, 1 resimden 1.
    • Disconnect the audio cable.
    FixBot'a Sor
    Yorum Ekle
  16. iBook G3 Clamshell Modem Replacement: adım 16, 1 resimden 1.
    • Grasp the upper case on either side of the keyboard space and rotate up and away from the screen.
    • You may be thinking you're about to break your upper case. Not to worry - the tabs holding the upper and lower cases together are very strong. Simply apply even pressure and continue to rotate the upper case up and away from the screen until it comes free.
    FixBot'a Sor
    Yorum Ekle
  17. iBook G3 Clamshell Modem Replacement, Modem: adım 17, 1 resimden 1.
    • Remove the following Phillips screws:
    • Remove the longer Phillips screw from the middle-rear of the modem shield.
    • Remove the three identical Phillips screws, two on either side of the EMI fingers, and the remaining one on the right side of the modem shield.
    • Remove the larger Phillips screw that secures the EMI fingers to the modem board.
    • Remove the EMI fingers.
    FixBot'a Sor
    Yorum Ekle
  18. iBook G3 Clamshell Modem Replacement: adım 18, 1 resimden 1.
    • Peel the modem shield away from the metal framework below, working from the right front and moving to the left.
    FixBot'a Sor
    Yorum Ekle
  19. iBook G3 Clamshell Modem Replacement: adım 19, 1 resimden 1.
    • Remove the Phillips screw from the left side of the modem.
    • Pry up the right side of the modem.
    FixBot'a Sor
    Yorum Ekle
  20. iBook G3 Clamshell Modem Replacement: adım 20, 1 resimden 1.
    • Lift the modem partially out and disconnect the cable on the left side.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
iRobot
1 İtibar
636 adet Kılavuz yazıldı
1Rehber Yorum
is there a way to upgrade the modem so it works with modern internet feeds?
richardmmckay - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 43
Her zaman: 5,682
