Ana içeriğe geç
iBook G3 Clamshell RAM Replacement
Neye ihtiyacın var
    1. iBook G3 Clamshell RAM Replacement, Battery: adım 1, 1 resimden 1.
      • Use a coin to turn both battery locking screws 90 degrees to the left.
      • Remove the battery cover.
      • Remove the battery from the computer by pulling up on the plastic tab.
      FixBot'a Sor
      Yorum Ekle
    1. iBook G3 Clamshell RAM Replacement, Airport Card: adım 2, 1 resimden 1.
      • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free. Note that the keyboard ribbon is still attached to the logic board, so you cannot completely remove the keyboard yet.
      • If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw (between F4 and F5 key) 180 degrees in either direction and try again.
      • Rotate the keyboard away from the screen and rest it face-down on the trackpad area.
      FixBot'a Sor
      Yorum Ekle
    2. iBook G3 Clamshell RAM Replacement: adım 3, 1 resimden 1.
      • If your computer does not have an airport card, you can skip the next two steps.
      • Grasp the clear plastic tab on the airport card and pull up and toward the display.
      FixBot'a Sor
      Yorum Ekle
    3. iBook G3 Clamshell RAM Replacement: adım 4, 1 resimden 1.
      • Hold the airport card in one hand and use your other hand to remove the antenna cable.
      FixBot'a Sor
      Yorum Ekle
    1. iBook G3 Clamshell RAM Replacement, Keyboard: adım 5, 1 resimden 1.
      • Remove the two Phillips screws that secure the RAM shield.
      FixBot'a Sor
      Yorum Ekle
    2. iBook G3 Clamshell RAM Replacement: adım 6, 1 resimden 1.
      • Grasp the wire metal bracket on top of the RAM shield and pull upward to remove the shield.
      FixBot'a Sor
      Yorum Ekle
    3. iBook G3 Clamshell RAM Replacement: adım 7, 1 resimden 1.
      • Pull up the keyboard connector cable by its clear plastic loop.
      FixBot'a Sor
      Yorum Ekle
    1. iBook G3 Clamshell RAM Replacement, RAM: adım 8, 1 resimden 1.
      • Your laptop should look approximately like this.
      FixBot'a Sor
      Yorum Ekle
    2. iBook G3 Clamshell RAM Replacement: adım 9, 1 resimden 1.
      • Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
      • Pull the chip directly out from its connectors.
      FixBot'a Sor
      Yorum Ekle
Sonuç
20 farklı kişi bu kılavuzu tamamladı.
iRobot
1 İtibar
636 adet Kılavuz yazıldı
1Rehber Yorum
I love that iFixit will sell you a quarter ($0.25) for $2.99 plus tax and shipping, another $3.29 shipping (totally reasonable), and sales tax for my location - the total is $6.59. I wish I could sell quarters for $6.59. 🤣
UnCoopervised - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 18
Son 30 gün: 86
Her zaman: 24,655
