Giriş
Use this guide to replace your inverter/AirPort cables.
Lay your iBook upside down on a flat surface.
Use a coin to rotate the battery locking screw 90 degrees clockwise.
Lift the battery out of the computer.
Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
Flip the keyboard over, away from the screen, and rest it face-down on the trackpad area.
Remove the four silver Phillips screws that secure the RAM shield.
Pull the keyboard cable up from the logic board, holding the cable as close to the connector as possible.
Use a spudger or small flathead screwdriver to remove the three rubber feet from the lower case.
"Close the display and flip the computer over." ...Seems like this instruction ought to be at the beginning of step 1 rather than step 2. In step one, the display is already closed and the computer flipped over. In step 2, you just keep it in this position and proceed from taking the battery out to removing the rubber feet.
Well, if you've had an iBook G4 this long, odds are the little rubber feet are falling off just from being looked at. Except the battery mounted one. That sucker is the Devils' Tower of little rubber feet.
Remove the three newly-revealed Phillips screws.
Use a spudger or small flathead screwdriver to pry up the three metal rings that housed the rubber bumpers.
Remove the three hex screws using a T8 Torx screwdriver.
Remove the two 4.5 mm Phillips screws on either sides of the battery contacts.
Push the thin rims of the lower case surrounding the battery compartment in, bending them past the tabs, and then lift up to free that corner of the lower case.
I find that a stiff nylon guitar pick will work if you don't have a spudger.
Definitely read the rest of the instructions now. I struggled at first... I was using my ipad with the step by step instructions and didnt scroll down past this photo, so I didnt see the sequence of how to loosen the tabs. in fact I didn't know where the tabs might be... Only discovered that part when I reassembled it. The spudger didn't work for me. Too soft, I used mostly a thin very small screwdriver.
There is a slot on the wall of the battery compartment that locks the lower case in place. Use a small flathead screwdriver to pry out the slot's lower rim and pull up on the lower case to free the slot from the tabs holding it.
Run a spudger along the seam between the lower case and upper case on the front of the computer to free the tabs locking the lower case. Pull up on the lower case and continue to use the spudger as necessary until you hear three distinct clicks.
Continue to run the spudger around the front right corner. There are two tabs on the port side of the computer, one near the front corner and one near the sound-out port.
There are three tabs over the optical drive that must be released before the lower case can come off. Slide the spudger into the lower case above the optical drive and run it toward the back of the computer until you hear three distinct clicks.
try using the spudger at the back near the vents. To be specific, on the left side of the hinge when faced upside-down. It's easier this way and it's described on Apple's official repair manual.
then put a library card or something between the outer enclosure and the optical drive enclosure then pull from the other side to free the casing
Turn the computer so that the back is facing you and pull the lower case up and toward you until the back tabs pop free.
Remove the small greasy springs with white plastic caps from either side of the battery contacts.
Have patience and follow the directions, the end result is up to you. In my case it worked. But I was a Technician TRW Automotive. and worked on Air Bag modules that was returned from customer's that needed them analyzed. I just retired after 26 years.
Remove the following 4 screws from the bottom shield:
Two 3 mm Phillips.
Two 7.5 mm Phillips.
Lift the bottom shield off.
Remove the two Phillips screws securing the DC-In board, removing tape as necessary.
Be careful here as the actual DC silver connector is raised from the chipboard so once you remove the screws use the spudger to gently lift out the DC IN board itself. There's some rubber casing around the silver connector too which got caught on the plastic casing of the laptop which required a bit of gentle poking to get free...
Is it necessary to remove DC cable?
@rickyzhang Yes, in order to remove the top case, this is required.
Deroute the cable from around the optical drive, removing tape as necessary.
Disconnect the DC-In cable from the logic board and angle the DC-In board out of its compartment.
Also, once I removed it, I thought there was more to do. It happened so quickly and effortlessly! I kept wondering when the difficult and trying part was coming. I was kind of disappointed by the lack of the challenge, but that's OK! The difficult part came from reversing the directions and getting the shield back in place. A cable covering on the back edge under the shield slipped out and prevented the metal tabs from seating correctly. Once I figured that out, it was smooth sailing!
Why? It‘s not necessary
Remove the two 3 mm Phillips screws inside the left edge of the battery tray.
Three 3 mm Phillips around the battery compartment.
Three 4.5 mm Phillips along the optical drive bezel. (a magnetic screwdriver may help to lift these screws out)
One 12 mm Phillips in the lower right corner.
Four 14.5 mm Phillips.
Turn over the computer and open it.
Use the flat side of a flathead screwdriver to remove the small magnet covering a screw near the middle of the computer.
Remove the following 7 screws from the edges of the keyboard area.
Three 2 mm Phillips along the right edge.
One 4.5 mm Phillips underneath where the magnet was.
One 6 mm Phillips with a small head in the lower left corner.
Two 6 mm Phillips with large heads, one in the upper left corner and one in the middle.
Carefully lift the upper case slightly and move it toward the front of the computer to reveal the trackpad connector. Use a spudger or your finger to disconnect the trackpad connector hidden beneath the white plastic tab.
After disconnecting the track pad connector, carefully rotate the upper case away from you and rest it against the display.
Although these instructions forewarn that these connectors are fragile, I would suggest emphasizing this in BOLD. When one of these connectors in the next couple steps pulls free from the logic board, as my speaker connector did with very little force, I was told by my Mac repair center that "...you're at the end of the road, period. There's no way we can re-solder that speaker connection". This may not be totally correct because other advice in iFixit suggests it is possible but regardless, the extremely small contact pads that need to be re-soldered really requires removing the entire logic board, experience with very tiny solder projects, and double the time and effort.
A second tool such as a tiny flat blade screw driver to hold down the connector that is soldered to the logic board while pulling/prying up on the male side of the connector with the spudger so that the soldered portion doesn't rip off the board was found to be helpful.
This set of instructions however is very complete, just read them carefully.
Follow crtolson's advice, but when prying the connectors, do it one side at a time, and use a LIGHT touch when doing so. Work each side slowly, HOLDING DOWN THE HEADER IN THE CENTER WITH A SMALL FLAT-HEAD PRECISION SCREWDRIVER, pulling up lightly with the spudger once per side. The connector will eventually come loose enough to lift it from the header. DO NOT USE YOUR FINGERS! Always use a spudger.
The instructions in CAPS are VERY important, lest you pull the header off the board. I've made this mistake myself, and I've been working on Mac notebooks for 20 years...
Use the sharp end of a spudger to disconnect the speaker cable connector.
The speaker cable connector was very tightly connected into the socket. When I tried to take it out the socket came right off the motherboard. In this case, in order to pull out the connector plug you must hold down the socket at the same time to make sure it isn't pulled from the motherboard.
i got a used book and opened it to exchange the hd to a bigger one. i found the airport/bluetooth cards connective socket dislocated and the speaker cables' socket as well. now i've led the free end of the speaker cable together with its connector through the opening of the kensington lock outside the case (no easy task but it went through) to fix a jack which goes into the headphones plug.
The male connector came out with the female one right off my logic board. I tied very carefully gluing it back. Appears that isnt enough; will need to be soldered back into place if I aver want to have sound again. USB, Bluetooth or AirPlay/AirTunes seem to be my remaining options.
Be very careful with this step!
Using the sharp end of a spudger, disconnect the connector for the blue and white power cables. Again, be careful to pry up only on the connector.
The upper case is now free and can be removed from the computer.
Quote from john50:
There is actually no need to remove the power plug if you are careful with the placement of the top cover. I had the whole plug pull of the board and had to solder it back again. Not an easy task had to use a magnifying glass to see it.
I wish I had read John's comment! I thought I was being careful to unplug without pulling and I pulled the whole plug out of the board too : ( I've never soldered anything before.......
Quote from john50:
As noted above, be very careful!
I also had the whole plug come off the board and had to solder it back. Definitely try and do it without removing the blue & white power cable.
Ditto. I didn't even notice that I'd torn the connector off the logic board until I went to put it all back together. It really is way too tight a connection and since you have so little room to work, it's VERY hard to pull it out without damage.
If you break this connection, anything else you're doing won't matter. Go slow, get a magnifying glass and perhaps try to hold town the part that's connected to the logic board as you attempt to pull out the connector....
If you have any problems or think that you can't do this, I'd say that you should stop, button it all back up and bring it to someone. Even a cheap, used logic board is around $250-350 -- and that's not worth it.
Quote from Matt:
Several people have mentioned soldering the plug back.......How exactly did you achieve this?! Are you experienced with micro-soldering? Were you able to salvage your laptop?! Although I got good advice to take it to a tv/electronics shop and have them solder the blue and white cables directly to the board, I have not done this. The comp is still neatly packaged by teardown step and sitting in a cardboard box. It's really annoying to look at this useless box of components that used to be a very nice little laptop : (
I would love to hear how you managed the repair.
Ann
Quote from Ann:
Ann
The plug has two holes in the back that slot into two pins on the board.
I slotted the pins in and the two wires on the front of the plug that need soldering to the board line up where they attach to the board.
I used a soldering iron with a flat tip (like a flat-head screwdriver) and pressed on the two wires at the same time for a second or two. That was long enough to melt the solder and reattach the wires. It took two attempts to get it attached correctly.
I didn't add any extra solder and I haven't had much experience with soldering.
Quote from Matt:
Quote from Ann:
Thanks Matt! That was a very complete description. My son (mechanical engineering student.....unfortunately, not electrical...lol) has some equipment. I'm hoping that he can manage it when he comes home this weekend. I do see the pins on the board and the two wires.
Thanks again sharing your approach!
Ann
Quote from JCarlos19:
Be careful with this step, when I did I was stuck with glue on the cable connector of the card.
DO NOT PRY!!!! just toasted my iBook following this lousy advise. Try pulling from the wires very lightly instead or cut back the surrounding metal to get a better approach. If anyone has a high res scan of the area surrounding the the plug and where to solder connection, I melted the socket and am now resorting to soldering directly to the board but its not going well.
this is a very tricky step
Man, this step is really hard. The hardest step of the iBook guide. It is possible to carefully wiggle it out. Bit by bit, wiggle the plug gently back and forth ever so slightly, so that it comes out. It is SO easy to break it. I've done it before. With patience, it can be done. Just take your time.
If you're careful and are able to remove the trackpad connector without damage, it is possible to lean the top case and metal shield against the screen, without having to remove the speaker and power connectors, while you replace the hard drive. You'll have to unstick the speaker cable from the shield first, remove the screws, and reroute the speaker cable out of the notch that it's in. SLOWLY remove the metal shield and CAREFULLY lean it up against the screen.
Remove the fifteen 3 mm Phillips screws securing the top shield to the computer.
Remove the following 16 screws:
Thirteen 3 mm Phillips.
One 3 mm Phillips. (actual screw not present in image)
Two 4 mm Phillips.
Lift the top shield up from the right side, minding the upper left corner, which may catch on the metal framework.
Disconnect the RJ-11 cable from the top of the modem.
Remove the two Phillips screws at the corners of the modem.
Lift the modem and modem shield from the bottom.
Remove the following three screws:
Two 3mm Phillips screws.
One 7.5 mm Phillips screw.
Lift the small plastic retaining bracket up and out of the computer.
Using a spudger, pry up the AirPort/Bluetooth board from the end closest to the hard drive. Be sure to pry against the metal framework, as shown in the picture.
Hold the AirPort/Bluetooth board in one hand and use a spudger to disconnect the two antenna cables.
Remove the AirPort/Bluetooth card from the computer.
Turn the computer over.
Disconnect the inverter cable from the logic board and deroute it from the metal framework, removing tape as necessary.
Turn the computer back over.
Disconnect the microphone cable at the front of the computer, between the left side of the hard drive and the metal framework, removing tape as necessary.
Although not absolutely essential, removal of the hard drive will give enough space to remove the connector with your fingers.
Use the black plastic handle to disconnect the display data cable from the logic board by pulling straight up.
Peel up the yellow tape holding the display data cable to the metal framework and remove the single Phillips screw beneath it.
De-route the AirPort antenna cables from the heat sink.
Support the display with one hand and remove the single Phillips screw on either side of the hinge (two screws total).
Tilt the display back, freeing it from the two metal alignment posts holding the hinges in place, and lift it from the computer.
Display remains.
Use a 1.5mm hex screwdriver to remove the two hex screws on either side of the display (four screws total).
Insert the flat end of a spudger perpendicular to the face of the display into the gap between the front and rear bezels near the upper left corner of the display.
Rotate the spudger away from the display to pry the rear bezel off the front bezel.
Run your spudger along the top edge of the front display bezel to evenly separate the two bezels.
Working down from the upper left corner, use the flat end of a spudger to pry the rear bezel away from the left edge of the display.
Use the flat end of a spudger to pry the rear bezel away from the right edge of the display.
If necessary, pry along the bottom edge of the rear bezel to separate it from the display assembly.
Lift the rear bezel off the display assembly.
Remove the large piece of tape near the lower right corner of the display.
Remove the single screw inserted through the piece of EMI tape near the bottom edge of the display (it's the first of the two clutch cover screws).
Use the tip of a spudger to remove the small washer under the screw you just removed.
Peel the aluminum/EMI tape as one piece off the cast aluminum frame of the clutch hinges.
Remove the pieces of readily removable tape from around the perimeter of the display.
Remove the piece of aluminum tape near the center of the LCD cover.
Peel back the piece of tape securing the display data cable ground loop to the thin steel LCD cover.
Remove the two Phillips screws securing each side of the LCD to the clutch hinge frame (four screws total).
Lift the thin steel LCD cover off the LCD.
Remove the second of the two Phillips screws securing the clutch cover to the cast aluminum frame of the clutch hinges.
Pull the clutch cover away from the front of the display.
To reinstall the two covers, hold one with tweezers, push clutch cover up. Tilt it and do the other side.
Remove the two pieces of tape over the display data/microphone cables near the lower edge of the display.
Check the microphone cable where it enters the display. The outer layer is often cracked and this causes the microphone to short out. Wrap a single layer of the yellow tape around the area where it touches the screen metal frame.
Use the tip of a spudger to lift the microphone out of the front bezel.
De-route the microphone cable from around the top and side of the display.
Disconnect the display data cable by pulling its connector away from the socket on the LCD.
Remove the display data cable from the display.
Remove the two pieces of tape covering the inverter/AirPort cables along the lower edge of the display.
Use the flat end of a spudger to push the backlight connector while gently pulling its cables away from the socket on the inverter.
Lift the LCD out of the front bezel and set it aside.
Remove the three Phillips screws securing the reed switch board and the AirPort antenna to the front bezel.
De-route the reed switch/AirPort antenna cables around the side of the display.
Gently peel the inverter cable ground strap off the cast aluminum frame of the clutch hinges.
While pulling the inverter cable away from its socket on the inverter board, use the tip of a spudger to push the connector out of its socket.
Remove the two Phillips screws securing the AirPort antenna to the front bezel.
De-route the AirPort antenna cable along the edge of the display.
If you have a 1.33 GHz 12" G4 iBook, simply remove the Inverter/AirPort cables.
For all other models, use the flat end of a spudger to remove the antenna board from the front bezel.
Remove the inverter/AirPort cables.
2 başka kişi bu kılavuzu tamamladı.
