Ana içeriğe geç
iBook G4 12" 1.33 GHz Keyboard Replacement
Neye ihtiyacın var
  1. iBook G4 12" 1.33 GHz Keyboard Replacement, Battery: adım 1, 2 resimden 1. iBook G4 12" 1.33 GHz Keyboard Replacement, Battery: adım 1, 2 resimden 2.
    • Lay your iBook upside down on a flat surface.
    • Use a coin to rotate the battery locking screw 90 degrees clockwise.
    • Lift the battery out of the computer.
  2. iBook G4 12" 1.33 GHz Keyboard Replacement, Keyboard: adım 2, 2 resimden 1. iBook G4 12" 1.33 GHz Keyboard Replacement, Keyboard: adım 2, 2 resimden 2.
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
    • If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw 180 degrees in either direction and try again.
    • Flip the keyboard over, away from the screen, and rest it face-down on the trackpad area.
  3. iBook G4 12" 1.33 GHz Keyboard Replacement: adım 3, 1 resimden 1.
    • Remove the four silver Phillips screws that secure the RAM shield.
  4. iBook G4 12" 1.33 GHz Keyboard Replacement: adım 4, 1 resimden 1.
    • Pull the keyboard cable up from the logic board, holding the cable as close to the connector as possible.
    • Make sure that you reconnect the keyboard cable before replacing the RAM shield.
Sonuç
10 farklı kişi bu kılavuzu tamamladı.
1Rehber Yorum
The screw is stripped. What should I do?
TheYootz Media Group - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 8
Son 30 gün: 28
Her zaman: 10,691
