Giriş
Replacing the plastic bottom case.
Lay your iBook upside down on a flat surface.
Use a coin to rotate the battery locking screw 90 degrees clockwise.
Lift the battery out of the computer.
Use a spudger or small flathead screwdriver to remove the three rubber feet from the lower case.
3 farklı kişi bu kılavuzu tamamladı.
