Giriş
Remove your rear display bezel to access your display's internals.
Parçalar
Lay your iBook upside down on a flat surface.
Use a coin to rotate the battery locking screw 90 degrees clockwise.
Lift the battery out of the computer.
Use a 1.5mm hex screwdriver to remove the two hex screws on either side of the display (four screws total).
3 farklı kişi bu kılavuzu tamamladı.
