Giriş
Upgrade or replace the CD, DVD, combo or SuperDrive.
Aletler
Parçalar
- 12.7 mm PATA Optical Bay PATA Hard Drive Enclosure
- iBook G4 12" 1.2 1.33 GHz Optical Drive Cable
- iBook G4 12" 800 1 GHz Optical Drive Cable Bracket
- iBook G4 12" 1.2 1.33 GHz Optical Drive Cable Bracket
- iBook G4 12" 24x Combo Drive
- iBook G4 12" 24x Combo Drive (CW-8124)
- iBook G4 12" 4x SuperDrive
- iBook G4 12" CD Drive
Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
Flip the keyboard over, away from the screen, and rest it face-down on the trackpad area.
Use a pin (or anything you like) to remove the three rubber feet from the lower case.
Remove the following 7 screws from the edges of the keyboard area.
Three 2 mm Phillips along the right edge.
One 4.5 mm Phillips underneath where the magnet was.
One 6 mm Phillips with a small head in the lower left corner.
Two 6 mm Phillips with large heads, one in the upper left corner and one in the middle
Remove the following 15 screws:
Fourteen 3 mm Phillips.
One 5.5 mm Phillips in the upper left corner.
Remove the following 4 screws:
One 3 mm Phillips in the channel between the optical drive and fan.
Two 6 mm Phillips from either end of the drive bezel.
One 6 mm Phillips with a collar from the bracket extending from the lower left corner of the drive.
26 farklı kişi bu kılavuzu tamamladı.
