Ana içeriğe geç
iBook G4 14" 933 MHz-1.33 GHz AirPort Extreme Card Replacement
Neye ihtiyacın var
  1. iBook G4 14" 933 MHz-1.33 GHz AirPort Extreme Card Replacement, Battery: adım 1, 1 resimden 1.
    • Use a coin to rotate the battery locking screw 90 degrees clockwise.
  2. iBook G4 14" 933 MHz-1.33 GHz AirPort Extreme Card Replacement: adım 2, 1 resimden 1.
    • Lift the battery out of the computer.
  3. iBook G4 14" 933 MHz-1.33 GHz AirPort Extreme Card Replacement, AirPort Extreme Card: adım 3, 1 resimden 1.
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
    • If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw 180 degrees in either direction and try again.
    • Flip the keyboard over, away from the screen, and rest it face-down on the trackpad area.
  4. iBook G4 14" 933 MHz-1.33 GHz AirPort Extreme Card Replacement: adım 4, 1 resimden 1.
    • Push the wire clasp away from the AirPort card and toward the display, then rotate up to free it from the RAM shield.
  5. iBook G4 14" 933 MHz-1.33 GHz AirPort Extreme Card Replacement: adım 5, 1 resimden 1.
    • Grasp the clear plastic tab on the AirPort card and pull toward the display.
  6. iBook G4 14" 933 MHz-1.33 GHz AirPort Extreme Card Replacement: adım 6, 1 resimden 1.
    • Hold the Airport card in one hand and use your other hand to remove the antenna cable.
Sonuç
19 farklı kişi bu kılavuzu tamamladı.
iRobot
1 İtibar
636 adet Kılavuz yazıldı
Bir Yorum
my ibook G4 doesnt have spot for air card to get pluged in it just a RAM im confused how to get internet . please hep fix it
kasey beebe - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 10
Her zaman: 17,223
