Giriş
The metallic bottom shield protects the logic board from electromagnetic interference.
Neye ihtiyacın var
Use a pin (or anything you like) to remove the three rubber feet from the lower case.
Remove the following 10 screws from the bottom shield:
Six 3 mm Phillips
Three 7.5 mm Phillips
One 14 mm Phillips
7 farklı kişi bu kılavuzu tamamladı.
