Giriş
Removing the rear display bezel does not require removal of the display assembly.
Neye ihtiyacın var
Use a 1.5 mm hex screwdriver to remove the two hex screws on either side of the display (four screws total).
If you don't have a 1.5 mm hex driver, you can probably get these screws out with a T6 Torx screwdriver. However, if you use a T6 Torx driver you'll be more likely to strip the screws.
Bir başkası bu kılavuzu tamamladı.
