Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. iControl Networks Piper cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. iControl Networks Piper Teardown, Cracking Open The Case: adım 1, 1 resimden 1.
    • Piper is held together with four "security Philips" screws located in the battery case. Each screw has a post in the middle, meant to foil use of a standard screwdriver. However....
    • If you don't have the right bit, just use a large #2 philips head screwdriver: the bit won't go deep enough to get tangled up in the security feature.
    • Once the screws are out use a plastic spludger to pry open four plastic clips holding the shell together.
  2. iControl Networks Piper Teardown, What's Inside: adım 2, 3 resimden 1. iControl Networks Piper Teardown, What's Inside: adım 2, 3 resimden 2. iControl Networks Piper Teardown, What's Inside: adım 2, 3 resimden 3.
    • Piper is dominated by a large speaker, and a Mallory PS-953Q security horn. It's loud. The CPU is a Texas Instruments TMS320DM365 media processor with a ZW0301 based Z-Wave module.
    • Piper uses two tiny antennas, one for Z-Wave one for WiFi.
    • That's it... a pretty simple layout.
Bryce Nesbitt
1.206 İtibar
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 6
Her zaman: 2,340
