Ana içeriğe geç
iDea USA CT 1020 Front & Rear Camera Assembly Replacement
Neye ihtiyacın var
  1. iDea USA CT 1020 Front & Rear Camera Assembly Replacement, Front & Rear Camera Assembly: adım 1, 1 resimden 1.
    • First, power down the tablet to avoid the chance of electrical shock or damaging the machine during repair work
    • Place the tablet on a clean surface with the screen down
  2. iDea USA CT 1020 Front & Rear Camera Assembly Replacement: adım 2, 2 resimden 1. iDea USA CT 1020 Front & Rear Camera Assembly Replacement: adım 2, 2 resimden 2.
    • Remove the back plastic casing of the tablet by releasing the plastic clips with a plastic opening tool or a spudger.
    • Be cautious and take your time here; the plastic clips are quite fragile.
  3. iDea USA CT 1020 Front & Rear Camera Assembly Replacement: adım 3, 1 resimden 1.
    • Use a plastic opening tool or spudger to lift and release the camera assembly ZIF tab.
    • Gently pull the ribbon cable free.
  4. iDea USA CT 1020 Front & Rear Camera Assembly Replacement: adım 4, 2 resimden 1. iDea USA CT 1020 Front & Rear Camera Assembly Replacement: adım 4, 2 resimden 2.
    • The camera is held in place by adhesive material on the back of the camera
    • To complete removal, peel the camera off the mother board
Sonuç
Bir başkası bu kılavuzu tamamladı.
David Lawrence
109 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S1-G3, Freund Spring 2018 IUPUI, Team S1-G3, Freund Spring 2018 üyesi
IUPUI-FREUND-S18S1G3
3 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 2
Son 30 gün: 10
Her zaman: 116
