Ana içeriğe geç
iDea USA CT 1020 Screen Replacement
Neye ihtiyacın var
  1. iDea USA CT 1020 Screen Replacement, Screen: adım 1, 1 resimden 1.
    • Start by powering off the device.
    • Place the device on a clean surface with the screen facing down.
  2. iDea USA CT 1020 Screen Replacement: adım 2, 2 resimden 1. iDea USA CT 1020 Screen Replacement: adım 2, 2 resimden 2.
    • Gently apply pressure to the back of the device where the backing case and screen meet.
  3. iDea USA CT 1020 Screen Replacement: adım 3, 2 resimden 1. iDea USA CT 1020 Screen Replacement: adım 3, 2 resimden 2.
    • Using a spudger or an iFixit opening tool, lift and release the camera assembly ZIF tabs.
    • Gently pull the ribbon cable free.
    • Repeat this for the other tab.
  4. iDea USA CT 1020 Screen Replacement: adım 4, 3 resimden 1. iDea USA CT 1020 Screen Replacement: adım 4, 3 resimden 2. iDea USA CT 1020 Screen Replacement: adım 4, 3 resimden 3.
    • Remove the disconnected camera by simply pulling it out of its socket.
    • Remove eight 25mm JIS #00 screws securing the motherboard.
    • The battery is glued to the back of the screen. Gently pry the battery off the screen, being careful not the bend the battery.
  5. iDea USA CT 1020 Screen Replacement: adım 5, 1 resimden 1.
    • Remove ten 25mm JIS #00 screws securing the screen.
  6. iDea USA CT 1020 Screen Replacement: adım 6, 2 resimden 1. iDea USA CT 1020 Screen Replacement: adım 6, 2 resimden 2.
    • Wedge the edges of the opening tools into the gap between the screen and the screen casing.
    • Be very careful while prying the screen from its casing to avoid damage.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Nathanael Carlson
183 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S1-G3, Freund Spring 2018 IUPUI, Team S1-G3, Freund Spring 2018 üyesi
IUPUI-FREUND-S18S1G3
3 Üyeler
4 adet Kılavuz yazıldı
Bir Yorum
SOOOOO GOOD , Well done
Nathanael Carlson - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 7
Her zaman: 150
