Ana içeriğe geç
iDea USA CT702 Button Replacement
Neye ihtiyacın var
  1. iDea USA CT702 Button Replacement, Button: adım 1, 3 resimden 1. iDea USA CT702 Button Replacement, Button: adım 1, 3 resimden 2. iDea USA CT702 Button Replacement, Button: adım 1, 3 resimden 3.
    • Place the device face up.
    • Use a plastic opening tool to gently pry open the black panel around the portholes.
  2. iDea USA CT702 Button Replacement: adım 2, 3 resimden 1. iDea USA CT702 Button Replacement: adım 2, 3 resimden 2. iDea USA CT702 Button Replacement: adım 2, 3 resimden 3.
    • Pry the rest of the back off; slowly apply pressure from each side to break each clip connection.
  3. iDea USA CT702 Button Replacement: adım 3, 2 resimden 1. iDea USA CT702 Button Replacement: adım 3, 2 resimden 2.
    • With a plastic spudger tool, pry the keys away from the black key mat to remove them.
    • It is easiest to start with the volume up button key and then work on freeing the next two.
  4. iDea USA CT702 Button Replacement: adım 4, 2 resimden 1. iDea USA CT702 Button Replacement: adım 4, 2 resimden 2.
    • Replace the button keys, starting with the outer and ending with the innermost key.
    • The back of each button key has a notch that matches an indent on the black button mat. Match the notches and the indents to properly align the buttons.
    • To replace the back cover, follow the first three steps in reverse order.
Sonuç
Daniel Brandt
201 İtibar
2 adet Kılavuz yazıldı
Ekip
Colorado Springs, Team 4-7, Panko Spring 2015 Colorado Springs, Team 4-7, Panko Spring 2015 üyesi
UCCS-PANKO-S15S4G7
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 7
Her zaman: 150
