Ana içeriğe geç
iDea USA CT702 Digitizer Glass Replacement
Neye ihtiyacın var
  1. iDea USA CT702 Digitizer Glass Replacement, Digitizer Glass: adım 1, 1 resimden 1.
    • Place tablet on the table with screen facing upright.
    • Starting from the portholes, use plastic opening tool to pry in between the front panel and back cover.
    • Follow the opening along the corners and sides until all latches are unclipped.
    • Remove back cover completely and place it outside of the work area.
  2. iDea USA CT702 Digitizer Glass Replacement: adım 2, 2 resimden 1. iDea USA CT702 Digitizer Glass Replacement: adım 2, 2 resimden 2.
    • Place tablet facing down.
    • Locate the 4mm screws along the perimeter of the motherboard.
    • There should be 4 screws.
    • Use Philips screw driver to unscrew each one, and carefully place screws in a safe place.
  3. iDea USA CT702 Digitizer Glass Replacement: adım 3, 3 resimden 1. iDea USA CT702 Digitizer Glass Replacement: adım 3, 3 resimden 2. iDea USA CT702 Digitizer Glass Replacement: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • After screws are removed, gently pull up on the ribbon wire connection to release all 3 wires from the motherboard.
    • Safely remove mother board and battery from tablet by using tweezers.
    • Make sure the small ribbon wires are not damaged when removing larger members.
  4. iDea USA CT702 Digitizer Glass Replacement: adım 4, 1 resimden 1.
    • Remove tape from battery pack, and dispose.
    • Be careful not to touch the wire/battery connection correctly, as it could result in injury.
  5. iDea USA CT702 Digitizer Glass Replacement: adım 5, 3 resimden 1. iDea USA CT702 Digitizer Glass Replacement: adım 5, 3 resimden 2. iDea USA CT702 Digitizer Glass Replacement: adım 5, 3 resimden 3.
    • After removing the battery pack and motherboard, the touch sensor unit should be visible.
    • Use small Philips screw driver to unscrew all 6 of the 2mm screws.
    • Use fingers and prying tool to remove the touch sensor unit from frame.
  6. iDea USA CT702 Digitizer Glass Replacement: adım 6, 3 resimden 1. iDea USA CT702 Digitizer Glass Replacement: adım 6, 3 resimden 2. iDea USA CT702 Digitizer Glass Replacement: adım 6, 3 resimden 3.
    • After the touch sensor is detached, only the plastic screen should remain.
    • Insert new touch sensor plate into the same position, aligning all screw inputs.
    • Insert all six of the 2mm. screws to connect the new touch sensor to the screen frame.
  7. iDea USA CT702 Digitizer Glass Replacement: adım 7, 1 resimden 1.
    • To continue reassembling the tablet, follow the steps in reverse.
    • Be careful when reconnecting battery, use safety goggles and gloves.
  8. iDea USA CT702 Digitizer Glass Replacement: adım 8, 3 resimden 1. iDea USA CT702 Digitizer Glass Replacement: adım 8, 3 resimden 2. iDea USA CT702 Digitizer Glass Replacement: adım 8, 3 resimden 3.
    • To reassemble tablet, follow these steps in reverse order.
Sonuç
David Kambich
110 İtibar
1 Kılavuz yazıldı
Ekip
Colorado Springs, Team 4-7, Panko Spring 2015 Colorado Springs, Team 4-7, Panko Spring 2015 üyesi
UCCS-PANKO-S15S4G7
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 3
Her zaman: 326
