Ana içeriğe geç
iDea USA CT702 Microphone Replacement
Neye ihtiyacın var
  1. iDea USA CT702 Microphone Replacement, Microphone: adım 1, 1 resimden 1.
    • Place the tablet face up with portholes facing you.
  2. iDea USA CT702 Microphone Replacement: adım 2, 2 resimden 1. iDea USA CT702 Microphone Replacement: adım 2, 2 resimden 2.
    • Use a fingernail, or a plastic opening tool to gently pry the black panel around the portholes.
    • Be gentle and take your time. Excessive force could damage the device.
  3. iDea USA CT702 Microphone Replacement: adım 3, 3 resimden 1. iDea USA CT702 Microphone Replacement: adım 3, 3 resimden 2. iDea USA CT702 Microphone Replacement: adım 3, 3 resimden 3.
    • Use your fingers to pry the rest of the back off; slowly apply pressure from each side to break each clip connection.
  4. iDea USA CT702 Microphone Replacement: adım 4, 1 resimden 1.
    • Once the back is off, position the tablet as shown and be sure to warm your soldering iron.
  5. iDea USA CT702 Microphone Replacement: adım 5, 1 resimden 1.
    • Place tip of the soldering iron on the end of the wire to break connection.
    • Remember to use proper safety precautions when soldering.
  6. iDea USA CT702 Microphone Replacement: adım 6, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Grip the new microphone with tweezers and place in the slot.
    • Solder the new connections while using tweezers to hold the speaker steady.
Sonuç
Benton Gray
201 İtibar
2 adet Kılavuz yazıldı
Ekip
Colorado Springs, Team 4-7, Panko Spring 2015 Colorado Springs, Team 4-7, Panko Spring 2015 üyesi
UCCS-PANKO-S15S4G7
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 5
Her zaman: 128
