Ana içeriğe geç
iDeaUSA CT8 Motherboard Replacement
Neye ihtiyacın var
  1. iDeaUSA CT8 Motherboard Replacement, Motherboard: adım 1, 3 resimden 1. iDeaUSA CT8 Motherboard Replacement, Motherboard: adım 1, 3 resimden 2. iDeaUSA CT8 Motherboard Replacement, Motherboard: adım 1, 3 resimden 3.
    • Place the tablet on a flat surface, facing upwards.
    • Starting from the portholes, use the plastic opening tools to remove the back cover of the tablet from the top half.
    • Being cautious of the wire connecting the speaker and the motherboard, place the front and back portion of the tablet close in proximity.
  2. iDeaUSA CT8 Motherboard Replacement: adım 2, 3 resimden 1. iDeaUSA CT8 Motherboard Replacement: adım 2, 3 resimden 2. iDeaUSA CT8 Motherboard Replacement: adım 2, 3 resimden 3.
    • Locate the five 3.5 mm black screws on the motherboard.
    • Use the #00 Phillips screwdriver to remove the screws, place them in an appropriate location.
  3. iDeaUSA CT8 Motherboard Replacement: adım 3, 1 resimden 1.
    • Carefully peel off the tape covering the circuit boards and blue ribbons. The tape can be disposed or saved for reuse.
  4. iDeaUSA CT8 Motherboard Replacement: adım 4, 3 resimden 1. iDeaUSA CT8 Motherboard Replacement: adım 4, 3 resimden 2. iDeaUSA CT8 Motherboard Replacement: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • After removing the tape, two blue ribbon wires can now be accessed. To disconnect, gently lift up the plastic ZIF tabs covering the wires.
    • Upon lifting the tab, the ribbons can now be safely pulled out of their connections.
    • To avoid breaking or damaging the plastic ZIF tabs, it is recommended to use tweezers.
  5. iDeaUSA CT8 Motherboard Replacement: adım 5, 1 resimden 1.
    • Locate the two wires connecting the speaker to the motherboard.
    • Use a soldering iron to desolder the red and black wires from their sockets.
    • Solder the speaker wires back in place during reassembly.
  6. iDeaUSA CT8 Motherboard Replacement: adım 6, 2 resimden 1. iDeaUSA CT8 Motherboard Replacement: adım 6, 2 resimden 2.
    • Disconnect the wires connecting the battery to the motherboard.
    • Start from the sides and gently wiggle the connection out until it;s loose enough to pull.
  7. iDeaUSA CT8 Motherboard Replacement: adım 7, 2 resimden 1. iDeaUSA CT8 Motherboard Replacement: adım 7, 2 resimden 2.
    • Pull out and free the motherboard from its position.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 146
