Ana içeriğe geç
iDeaUSA CT8 Power Button Replacement
Neye ihtiyacın var
  1. iDeaUSA CT8 Power Button Replacement, Power Button: adım 1, 3 resimden 1. iDeaUSA CT8 Power Button Replacement, Power Button: adım 1, 3 resimden 2. iDeaUSA CT8 Power Button Replacement, Power Button: adım 1, 3 resimden 3.
    • Place the tablet on a flat surface, facing upwards.
    • Starting from the portholes, use the plastic opening tools to remove the back cover of the tablet from the top half.
    • Being cautious of the wire connecting the speaker and the motherboard, place the front and back portion of the tablet close in proximity.
  2. iDeaUSA CT8 Power Button Replacement: adım 2, 2 resimden 1. iDeaUSA CT8 Power Button Replacement: adım 2, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • On the tablet’s back cover, locate the power button.
    • Use tweezers to remove button’s padding that holds it in place.
  3. iDeaUSA CT8 Power Button Replacement: adım 3, 1 resimden 1.
    • To remove the power button, use a plastic opening tool to nudge the button out of position.
    • A gentle push from the button’s exterior side should be enough.
  4. iDeaUSA CT8 Power Button Replacement: adım 4, 1 resimden 1.
    • The power button is now removed. Adjust accordingly or replace it
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 118
