Ana içeriğe geç
iDevices iGrill Probe Replacement
Neye ihtiyacın var
  1. iDevices iGrill Probe Replacement, Probes: adım 1, 1 resimden 1.
    • Remove the back plastic cover from the device; this should allow you access to the batteries.
  2. iDevices iGrill Probe Replacement: adım 2, 1 resimden 1.
    • Remove the batteries from the device.
  3. iDevices iGrill Probe Replacement: adım 3, 2 resimden 1. iDevices iGrill Probe Replacement: adım 3, 2 resimden 2.
    • Remove five black 10 mm Phillips #0 screws from the back side of the device.
    • Remove two silver-colored 5 mm screws using a Phillips screwdriver. The screws are located on the left side of the internal cover.
    • Remove the accompanying plastic tabs under the screws.
    • Gently pull off the back cover from the device.
  4. iDevices iGrill Probe Replacement: adım 4, 3 resimden 1. iDevices iGrill Probe Replacement: adım 4, 3 resimden 2. iDevices iGrill Probe Replacement: adım 4, 3 resimden 3.
    • If you have not removed the 2 silver-colored screws; you must remove them now.
    • Remove the metal terminals from the battery slot closest you.
    • Pull the remaining metal terminals out of their slots. Position them such that when removing the internal cover they will not be caught.
    • Remove the internal cover.
  5. iDevices iGrill Probe Replacement: adım 5, 1 resimden 1.
    • After the internal plastic case has been removed, you will have access to the probe contacts.
    • You should then insert the probes to check their connection to the probe terminals.
  6. iDevices iGrill Probe Replacement: adım 6, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Using a pair of tweezers, bend the probe contacts back in place. The tweezers will touch the probe terminals when inserted.
Sonuç
Michelle Nguyen
204 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team 3-4, Harley Spring 2016 IUPUI, Team 3-4, Harley Spring 2016 üyesi
IUPUI-HARLEY-S16S3G4
4 Üyeler
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 8
Her zaman: 1,107
