Ana içeriğe geç
iFixit 26 Bit Driver Kit Technique for Removing Bits
Neye ihtiyacın var
  1. iFixit 26 Bit Driver Kit Technique for Removing Bits, iFixit 26 Bit Driver Kit Technique for Removing Bits: adım 1, 1 resimden 1.
    • Note how challenging it is to remove a required bit from the kit. Argh!
  2. iFixit 26 Bit Driver Kit Technique for Removing Bits: adım 2, 1 resimden 1.
    • Find yourself a rubber band...
  3. iFixit 26 Bit Driver Kit Technique for Removing Bits: adım 3, 1 resimden 1.
    • Wrap said band around the bit and viola! easy bit extraction enabled. You might want to keep that handy rubber band with the kit now.
  4. iFixit 26 Bit Driver Kit Technique for Removing Bits: adım 4, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Alternate, no-rubber-band solution: use the tweezers supplied in the bit driver kit.
Sonuç
49 farklı kişi bu kılavuzu tamamladı.
aaronmiller
1.394 İtibar
1 Kılavuz yazıldı
2Kılavuz Yorumları
I want to order the 26 bit driver kit technique for removing bits
clement mEnThChEl - Yanıt
I just use the included bit driver. Once removed, reverse it and I am ready to go!
P.S. Anyone got a guide on how to fix the hinge. Spring is loose and the bit tray is out.
Harold - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 48
Her zaman: 5,813
