Ana içeriğe geç
iFixit 26 Bit Driver Kit Technique for Removing Bits
Neye ihtiyacın var
  1. iFixit 26 Bit Driver Kit Technique for Removing Bits, iFixit 26 Bit Driver Kit Technique for Removing Bits: adım 1, 1 resimden 1.
    • Note how challenging it is to remove a required bit from the kit. Argh!
  2. iFixit 26 Bit Driver Kit Technique for Removing Bits: adım 2, 1 resimden 1.
    • Find yourself a rubber band...
  3. iFixit 26 Bit Driver Kit Technique for Removing Bits: adım 3, 1 resimden 1.
    • Wrap said band around the bit and viola! easy bit extraction enabled. You might want to keep that handy rubber band with the kit now.
  4. iFixit 26 Bit Driver Kit Technique for Removing Bits: adım 4, 1 resimden 1.
    • Alternate, no-rubber-band solution: use the tweezers supplied in the bit driver kit.
Sonuç
48 farklı kişi bu kılavuzu tamamladı.
aaronmiller
1.376 İtibar
1 Kılavuz yazıldı
Bir Yorum
I want to order the 26 bit driver kit technique for removing bits
clement mEnThChEl - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 38
Her zaman: 4,689
