Ana içeriğe geç
iFixit Adhesive Remover Preparation
Neye ihtiyacın var
    1. iFixit Adhesive Remover Preparation, iFixit Adhesive Remover Preparation: adım 1, 2 resimden 1. iFixit Adhesive Remover Preparation, iFixit Adhesive Remover Preparation: adım 1, 2 resimden 2.
      • iFixit adhesive remover contains acetone, a mild skin and eye irritant.
      • Wear eye protection when handling and applying the adhesive remover. (Eye protection is included in your kit.)
      • Do not wear contact lenses without eye protection.
      • Protective gloves are also included in your kit. If you are concerned about possible skin irritation, put your gloves on now.
      FixBot'a Sor
      Yorum Ekle
    2. iFixit Adhesive Remover Preparation: adım 2, 3 resimden 1. iFixit Adhesive Remover Preparation: adım 2, 3 resimden 2. iFixit Adhesive Remover Preparation: adım 2, 3 resimden 3.
      • Pull off the black rubber stopper from your bottle of adhesive remover.
      • Twist to loosen or remove the bottle cap before you cut the applicator tip.
      • This unseals the bottle and allows the pressure to equalize before you cut the applicator tip. If you skip this step, the adhesive remover may spray out unexpectedly when the tip is cut.
      • Use scissors to cut off the sealed tip of the applicator.
      • Cutting close to the narrow tip will give you better control so you can apply the adhesive remover in small amounts.
      • Twist and close the bottle cap securely before you proceed further.
      FixBot'a Sor
      Yorum Ekle
Bitiş Çizgisi
15 farklı kişi bu kılavuzu tamamladı.
Arthur Shi
345.291 İtibar
915 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
63.489 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 13
Son 7 gün: 110
Son 30 gün: 496
Her zaman: 27,685
