Ana içeriğe geç
iFixit Precision Bit Driver Magnet Replacement
Neye ihtiyacın var
    1. iFixit Precision Bit Driver Magnet Replacement, Removing the cap: adım 1, 2 resimden 1. iFixit Precision Bit Driver Magnet Replacement, Removing the cap: adım 1, 2 resimden 2.
      • Follow the Cap Replacement guide in reverse.
      • I found doing a few loops around the handle first helped tighten the floss around the cap
      FixBot'a Sor
      Yorum Ekle
    2. iFixit Precision Bit Driver Magnet Replacement, Hammering out the magnet: adım 2, 3 resimden 1. iFixit Precision Bit Driver Magnet Replacement, Hammering out the magnet: adım 2, 3 resimden 2. iFixit Precision Bit Driver Magnet Replacement, Hammering out the magnet: adım 2, 3 resimden 3.
      • Place the screwdriver vertically, bit shaft down on a hard surface.
      • You will be hammering against that surface. Make sure it's either resistant, or that damage to it doesn't matter
      • Insert a 3mm allen key all the way down.
      • The allen key's 90° should not touch the end of the driver. It needs to be able to be pushed further.
      • Use a hammer to dislodge the old magnet. You may need to hit hard and a few times
      • Once the magnet is dislodged, you can blow through the driver or use a long pokey thing to remove it completely
      FixBot'a Sor
      Yorum Ekle
    3. iFixit Precision Bit Driver Magnet Replacement, Inserting the new magnets: adım 3, 3 resimden 1. iFixit Precision Bit Driver Magnet Replacement, Inserting the new magnets: adım 3, 3 resimden 2. iFixit Precision Bit Driver Magnet Replacement, Inserting the new magnets: adım 3, 3 resimden 3.
      • Attach the new magnet (in this case 2x 2mm*4mm disc magnets, original was a 4*4mm) to one of your useless bits. I used the triangle one
      • You may want to add a dab of glue to the back of your magnets. I didn't feel the need, a press fit was all that was needed
      • Insert the bit. It may not go all the way to the required depth
      • Place the screwdriver, cap side down, on your makeshift anvil/surface
      • Give it a good few hits with the hammer, to push it back in.
      • Hits sound different when you're all the way in. When that's the case, you can't go further
      FixBot'a Sor
      Yorum Ekle
    4. iFixit Precision Bit Driver Magnet Replacement, Reattaching the cap: adım 4, 2 resimden 1. iFixit Precision Bit Driver Magnet Replacement, Reattaching the cap: adım 4, 2 resimden 2.
      • Follow the Cap Replacement guide to re attaching the cap to put it back on
      • I couldn't tighten mine back all the way, I may have damaged some threads whilst hammering the allen key.
      FixBot'a Sor
      Yorum Ekle
    5. iFixit Precision Bit Driver Magnet Replacement, Done!: adım 5, 1 resimden 1.
      • You've done it. You've fixed your IFixit driver that you bought to fix things. The fixer is fixed.
      • Maybe this wasn't worth it, and a replacement screwdriver was just an email to support away, but why do that, when you can fix it
      FixBot'a Sor
      Yorum Ekle
Sonuç
Congratulaitons. Your screwdriver is fixed.
Now you that you have 4mm disc magnets, why not stick one to the bottom of your 4mm hex driver bit, and give you a magnetic bit extension for hard to reach screws.
2 farklı kişi bu kılavuzu tamamladı.
BrokenClock
184 İtibar
1 Kılavuz yazıldı
1Rehber Yorum
wow this is handy. Thank you.
Opetaja - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 39
Son 30 gün: 172
Her zaman: 3,957
