Ana içeriğe geç
iFixit Precision Bit Driver Reassembly
Neye ihtiyacın var
  1. iFixit Precision Bit Driver Reassembly, How to reinstall the bearing cap: adım 1, 3 resimden 1. iFixit Precision Bit Driver Reassembly, How to reinstall the bearing cap: adım 1, 3 resimden 2. iFixit Precision Bit Driver Reassembly, How to reinstall the bearing cap: adım 1, 3 resimden 3.
    • Unscrew the center of the barrel
    • Note: Assembly utilizes threat locker. You may need tools to unscrew. Use a small piece of duct tape on the smooth part to protect the aluminum.
    • Use pliers on the duct tape, and an adjustable wrench on the flat of the knurled part near the bottom of the screw driver to create leverage to unscrew the barrel.
    FixBot'a Sor
    Yorum Ekle
  2. iFixit Precision Bit Driver Reassembly: adım 2, 3 resimden 1. iFixit Precision Bit Driver Reassembly: adım 2, 3 resimden 2. iFixit Precision Bit Driver Reassembly: adım 2, 3 resimden 3.
    • Next use a 2.5mm hex key with a long shaft such that it fits all the way through the top half of the screw driver.
    • Insert the bearing/top assembly onto the hex key, and begin tightening the bearing assembly into the screwdriver.
    • Note: threadlocker should not be necessary here as there is an O ring that is responsible for maintaining the thread loading
    FixBot'a Sor
    Yorum Ekle
  3. iFixit Precision Bit Driver Reassembly: adım 3, 1 resimden 1.
    • Screw the two halves of the barrel back together.
    • While not necessary, some thread locker can be applied to the threads on the upper half of the barrel to prevent the two halves from separating. Be sure to use non-permanent thread locker in case you need to do this again in the future!
    FixBot'a Sor
    Yorum Ekle
  4. iFixit Precision Bit Driver Reassembly: adım 4, 1 resimden 1.
    • Voila, enjoy your screw driver.
    FixBot'a Sor
    Yorum Ekle
Sonuç
There are other ways to do this, such as the floss trick. But if you have the tools lying around here's the proper way to reassemble your iFixit Precision screwdriver!
2 farklı kişi bu kılavuzu tamamladı.
Ricky H
199 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 43
Son 30 gün: 147
Her zaman: 1,987
