Ana içeriğe geç
iFixit Screwdriver Grip Replacement
Neye ihtiyacın var
    1. iFixit Screwdriver Grip Replacement, Grip: adım 1, 1 resimden 1.
      • Your iFixit screwdriver has seen better days. Its been in one to many tight places and its mated with far too many screw faces. Its been a part of so many fixes that it seriously would appreciate some down time.
      • But no, you want to keep using this driver. You want it to weather the next fix. It's just not performing like it used to in its glory days.
      • So what is this anyway? A guide to fix a screwdriver? You bet.
      FixBot'a Sor
      Yorum Ekle
    2. iFixit Screwdriver Grip Replacement: adım 2, 3 resimden 1. iFixit Screwdriver Grip Replacement: adım 2, 3 resimden 2. iFixit Screwdriver Grip Replacement: adım 2, 3 resimden 3.
      • If you're an owner of the original iFixit screwdriver included in the 54 Bit Driver Kit, you've probably noticed that the rubber grip rings on the screw driver wear out over time, develop small tears and fall off.
      • Regardless if they wear from over-torquing or the build up of oils from your hands, it's quite frustrating to lose the grip on a prised screwdriver.
      FixBot'a Sor
      Yorum Ekle
    3. iFixit Screwdriver Grip Replacement: adım 3, 2 resimden 1. iFixit Screwdriver Grip Replacement: adım 3, 2 resimden 2.
      • Here's the solution: throw some o-rings on it.
      • 1/16in thick, 7/16 OD, 5/16 ID work wonders.
      • OD= outside diameter.
      • ID= inside diameter.
      • I picked up a bunch from my local hardware store. They are manufactured by Midwest Fastner. They cost $0.31 USD each.
      FixBot'a Sor
      Yorum Ekle
    4. iFixit Screwdriver Grip Replacement: adım 4, 1 resimden 1.
      • So how do you remove the old grip? Simple, use your fingernails!
      • Otherwise, use toothpicks!
      • Remember the mohs scale? Wood won't carelessly scratch your metal tool!
      FixBot'a Sor
      Yorum Ekle
    5. iFixit Screwdriver Grip Replacement: adım 5, 2 resimden 1. iFixit Screwdriver Grip Replacement: adım 5, 2 resimden 2.
      • That's it. If your grip's gone, shower your screwdriver in o-rings.
      • Enjoy that new, glistening rubber grip on your screwdriver.
      FixBot'a Sor
      Yorum Ekle
Sonuç
To reassemble your screwdriver, follow these instructions in reverse order.
8 farklı kişi bu kılavuzu tamamladı.
Anthony Kouttron
5.764 İtibar
5 adet Kılavuz yazıldı
2Kılavuz Yorumları
Worked like a charm.
Now all I need is to get instructions on how to assemble a replacement 54-bit driver kit case….
Jason Higley - Yanıt Paylaş
Thanks for publishing the sizes on this. I have rejuvenated my driver grip.
However, like the other poster, the plastic storage case on mine has cracked and I too would want a replacement.
alan - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 20
Son 30 gün: 90
Her zaman: 3,648
