Ana içeriğe geç
iHealth Edge Band Replacement
  1. iHealth Edge Band Replacement, Band: adım 1, 1 resimden 1.
    • Pull the elastic band away from the device as shown. You will need to use one hand to support the device and pull the elastic band with the other at about a 45 degree angle.
  2. iHealth Edge Band Replacement: adım 2, 1 resimden 1.
    • Pull the elastic band away from the device, you should now have the device with no band as shown.
  3. iHealth Edge Band Replacement: adım 3, 2 resimden 1. iHealth Edge Band Replacement: adım 3, 2 resimden 2.
    • Place the elastic band into the channel in the side of the device shown in the picture. The band will pull into the channel and lock into place.
  4. iHealth Edge Band Replacement: adım 4, 1 resimden 1.
    • After pulling the band into place the guide is now complete. Your iHealth Edge should be ready for use.
Sonuç
This guide will show you how to replace the arm band.
Gabrielle Bettegnies
349 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team S1-G4, Freund Fall 2017 IUPUI, Team S1-G4, Freund Fall 2017 üyesi
IUPUI-FREUND-F17S1G4
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 10
Her zaman: 395
