Ana içeriğe geç
iHealth Edge Battery Replacement
Neye ihtiyacın var
    1. iHealth Edge Battery Replacement, Battery: adım 1, 1 resimden 1.
      • Lightly heat device with hair dryer for 15 seconds to soften adhesive.
      FixBot'a Sor
      Yorum Ekle
    2. iHealth Edge Battery Replacement: adım 2, 1 resimden 1.
      • After heating adhesive, firmly pry apart the two halves.
      FixBot'a Sor
      Yorum Ekle
    3. iHealth Edge Battery Replacement: adım 3, 1 resimden 1.
      • Remove polymer cover that is protecting the mother board, it should just come out when two halves are separated.
      FixBot'a Sor
      Yorum Ekle
    4. iHealth Edge Battery Replacement: adım 4, 1 resimden 1.
      • Use a spudger or plastic opening tool to assist the removal of the motherboard. Pry up on two tabs and the mother board will pop out.
      FixBot'a Sor
      Yorum Ekle
    5. iHealth Edge Battery Replacement: adım 5, 1 resimden 1.
      • This shows the mother board and battery out and exposed.
      FixBot'a Sor
      Yorum Ekle
    6. iHealth Edge Battery Replacement: adım 6, 1 resimden 1.
      • You must remove the solder from two wires from the motherboard that are connected to the battery.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Gabrielle Bettegnies
349 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team S1-G4, Freund Fall 2017 IUPUI, Team S1-G4, Freund Fall 2017 üyesi
IUPUI-FREUND-F17S1G4
4 Üyeler
1Rehber Yorum
where can I buy the new battery?? or what are the characteristics of the battery?
Fafi Dau - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 25
Her zaman: 1,774
