Giriş
This guide will aid in properly removing the back cover of the device. Through doing this, you will have access to the internal pieces of the device and allow in further adjustments.
Parçalar
Hiçbir parçaya gerek yok.
  1. Use your fingers to slide the battery case cover off in the direction of the arrows.
    • Use your fingers to slide the battery case cover off in the direction of the arrows.
  2. Remove and discard the old batteries. Use the detailing brush and a paper towel to remove any corrosion left by previous batteries. Use the detailing brush and a paper towel to remove any corrosion left by previous batteries.
    • Remove and discard the old batteries.
    • Use the detailing brush and a paper towel to remove any corrosion left by previous batteries.
  3. Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
  4. Unscrew the four outer 1.0 mm screws with a Phillips-Head screwdriver. Screws will be magnetized in position and will require the use of tweezers to be removed.
    • Unscrew the four outer 1.0 mm screws with a Phillips-Head screwdriver.
      • Screws will be magnetized in position and will require the use of tweezers to be removed.
    • Push down gently on the battery case cover and slide it in the direction the arrows indicate. Remove the batteries.
    • Unscrew the 0.6 mm screw located in the center of the battery case.
    • Keep 10 mm and 0.6 mm screws separate from each other for reassembly.
  5. Remove the back cover carefully; there are many wires that connect it to the device. Remove the back cover carefully; there are many wires that connect it to the device.
    • Remove the back cover carefully; there are many wires that connect it to the device.
Sonuç
Cristina Garcia
301 İtibar
3 adet Kılavuz yazıldı
Takım
Clemson, Team 3-4, Benson Fall 2014 Clemson, Team 3-4, Benson Fall 2014 üyesi
CLEM-BENSON-F14S3G4
5 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 Gün: 1
Son 30 Gün: 3
Her zaman: 196
