Ana içeriğe geç
iHome IBT16 Micro USB port Replacement
Neye ihtiyacın var
    1. iHome IBT16 Micro USB port Replacement, Base Plate: adım 1, 2 resimden 1. iHome IBT16 Micro USB port Replacement, Base Plate: adım 1, 2 resimden 2.
      • Make sure to flip the device over to get into the correct orientation
      • Using the Philips #00 Screwdriver, unscrew and remove the four 9mm black screws on the base plate of the device.
      • Make sure to keep these screws in a safe location so you don't lose them
      FixBot'a Sor
      Yorum Ekle
    2. iHome IBT16 Micro USB port Replacement: adım 2, 2 resimden 1. iHome IBT16 Micro USB port Replacement: adım 2, 2 resimden 2.
      • Using the plastic opening tool, insert into the crack between the base plate and the main body of the device
      • Using a lever like motion, push the opening tool down thus lifting the plate
      • You will need to use your fingers to lift the base plate off the main body of the device
      • The motherboard is directly underneath the base plate
      FixBot'a Sor
      Yorum Ekle
    1. iHome IBT16 Micro USB port Replacement, Micro USB port: adım 3, 1 resimden 1.
      • Inside the iHome remove the two silver Phillips screws that are on the motherboard.
      • Connect the ground strap to ground, and then put the strap around your wrist.
      FixBot'a Sor
      Yorum Ekle
    2. iHome IBT16 Micro USB port Replacement: adım 4, 1 resimden 1.
      • Take the motherboard out of the device, use the plastic opening tool to ensure the power switch doesn't get stuck.
      FixBot'a Sor
      Yorum Ekle
    3. iHome IBT16 Micro USB port Replacement: adım 5, 1 resimden 1.
      • On the other side of the motherboard unsolder the two biggest solder joints under the micro USB.
      FixBot'a Sor
      Yorum Ekle
    4. iHome IBT16 Micro USB port Replacement: adım 6, 1 resimden 1.
      • On the side of the motherboard that the micro USB connector is there are five surface mount solder joints at the back of the connector. Unsolder these five solder joints.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Steven Ferreira
222 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S3-G6, Botvin Spring 2017 UMass Dartmouth, Team S3-G6, Botvin Spring 2017 üyesi
UMASSD-BOTVIN-S17S3G6
2 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 21
Her zaman: 1,729
