Ana içeriğe geç
iHome IBT16 Power Switch Replacement
Neye ihtiyacın var
  1. iHome IBT16 Power Switch Replacement, Base Plate: adım 1, 2 resimden 1. iHome IBT16 Power Switch Replacement, Base Plate: adım 1, 2 resimden 2.
    • Make sure to flip the device over to get into the correct orientation
    • Using the Philips #00 Screwdriver, unscrew and remove the four 9mm black screws on the base plate of the device.
    • Make sure to keep these screws in a safe location so you don't lose them
  2. iHome IBT16 Power Switch Replacement: adım 2, 2 resimden 1. iHome IBT16 Power Switch Replacement: adım 2, 2 resimden 2.
    • Using the plastic opening tool, insert into the crack between the base plate and the main body of the device
    • Using a lever like motion, push the opening tool down thus lifting the plate
    • You will need to use your fingers to lift the base plate off the main body of the device
    • The motherboard is directly underneath the base plate
  3. iHome IBT16 Power Switch Replacement, Power Switch: adım 3, 2 resimden 1. iHome IBT16 Power Switch Replacement, Power Switch: adım 3, 2 resimden 2.
    • Using the Philips #00 screwdriver, unscrew and remove the two silver 10mm screws holding the motherboard
    • Don't misplace the screws! Keep them in a safe place while working on the device
    • Make sure to ground yourself prior to continuing at this point
  4. iHome IBT16 Power Switch Replacement: adım 4, 1 resimden 1.
    • Using the plastic opening tool, pull the motherboard out of the casing
    • Make sure to lift it out at an angle to the back, as the plastic power switch is attached to the board and can be broken
  5. iHome IBT16 Power Switch Replacement: adım 5, 2 resimden 1. iHome IBT16 Power Switch Replacement: adım 5, 2 resimden 2.
    • Desolder the 10 points holding the power switch to the motherboard
    • Once complete, simply remove the switch from the board
Sonuç
Bir başkası bu kılavuzu tamamladı.
Ryan Edwards
331 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S3-G6, Botvin Spring 2017 UMass Dartmouth, Team S3-G6, Botvin Spring 2017 üyesi
UMASSD-BOTVIN-S17S3G6
2 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 13
Her zaman: 822
